Thread: fault code help
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default fault code help
    hi
    got the new car home today and plugged into dianostic reader and got these fault codes, i cleared them and they havent come back.
    p0130-52 no plausibility between o2 sensor 1 blank 1 and o2 sensor 2 blank 1
    u2103-70 can-bus node no communication
    u2139-00 can-bus no communication with cim (steering column module)
    u2117-71 invalid data from dis (display)
    i know they could be old, so will re check in a week or 2 but wondered if any were bad ones?
    many thanks
    p.s do i need to update the factory nav and how?, i have 2 discs for it?
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Top one possibly faulty sensor new one replaced I bet and the other 3 looks like someone disconnected the hu I got that fault when I took mine out and turned the ignition on cleared it and it's fine now
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The bottom 3 usually come up, if everything is working fine I would ignore them.
    Ipswich,.UK
    thanks guys
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
u2117-71 opel signum
