Thread: vec 1.9 cdti 120 sri
    Aug 2012
    wirral, wallasey
    Default vec 1.9 cdti 120 sri
    hi, ive just purchased my 1st vaux vectra, its a 1.9 cdti sri 120, a pretty tidy motor, 2006 2 owners with 110k, has history, however i think its using/buring oil, when i bought the car 2 weeks back the oil level looked low, i put approx 300ml of oil into it, ive done bout 500 miles, mix of m-way and town, and today the oil warning light came on, i had to put approx 500ml to put level near maximun on dip stick, so in total the car seems to of used 800ml of oil in approx 500-550 miles :S seems pretty excessive as my 2008 saab aero ttid hasnt used a droop in over 10k!!!!....any advice would be much appreciated as im a tad worried...
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Welcome to the site. Pics are the law by the way lol. Sorry i cant help with the oil problem but im sure someone on here can :-)
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Hi mate,is there any oil on the ground where you park it up,whilst driving do you ever notice smoke coming from exhaust
    Aug 2012
    wirral, wallasey
    ha, for some reason im unable to put a profile pic up!!! cant even upload any pics of my vec into my garage section ....the car doesnt really smoke when driving, smokes a bit when started from cold, blue, when driven hard i get the usual very small amount of smoke as you do from any diesel, theres nothing much being left on the ground, however the under tray is a bit wet with oil, i suspect the small pipe on the oil filter housing, it doesnt seem to be leaking when parked and not running, but i suspect its leaking when being driven, the car was a bargain piked it up for 1700, so im expecting to have to spend a few pennies on it,
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Always let the car stand for a while then dip the oil more than once, a lot of vauxhalls are known for showing tricky levels on the dipstick especially on the first dip, If you are using oil try 10/40 semi synth as a last resort if its still burning oil try 15/40 to prove the problem is within the bores, A lot will only use 5/30 but rest assured after many many vx diesels & using varied oils you wont have any problems with these grades of good quality oils, ( I've put all of these grades in every engine I've owned & never had 1 single engine part failure or any usage of oil!).
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    I use 10/40 semi VX stuff. Have done for 7 yrs on this car. Now on 115k, so maybe try swopping to 10/40 semi.
    You need to take under tray off while engine running and put the car on ramps and see if you can see any drips/ leaks.
    Have you checked your radiator coolant for cross contamination?
    Aug 2012
    wirral, wallasey
    coolent is clean and in good condition mate, ive got a feeling it may be burning it a bit, car has full history at regular intervals, and 110k isnt a massive amount of miles, so i dont se any reason for such a large oil consumption, and its not overly smokey, just a bit of blue smoke visable oncold start, going to get the front end on stands now and take the cover off...thanks!!!
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  3. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
