Thread: Towing electrics
    Regular Member iain.condliffe's Avatar
    Feb 2007
    Cheshire
    Default Towing electrics
    Hi All,
    I have fitted a Westfalia towbar and a right connections wiring loom (the connector is stamped GM so Im happy its actually genuine) along with the fridge / charger connection.
    Plugged the caravan in and nothing. All the connectors and fuse checked but still nothing.
    I then had the car Tech 2'd.
    So this morning I connect up again, there is now power coming coming through the 13 pin socket to the fridge and battery charge pin but nothing for the lights. I have stripped the boot back again and got the multi meter out. The rear electric module in the boot is exposed and ive unclipped the loom plug. There is a permanant live on the car side of the loom but when the lights are on, no other pin seems to have a power.
    Now to me this suggests that Tech 2 hasnt connected the rear electric module rather than the loom / socket being faulty.
    Anyway, the car is going back on Monday as the tech was off today. Any ideas to go armed with though?
    thanks in advance
    Iain
    Jun 2006
    St. Helens,Merseyside
    aswell as fitting/pluging the loom into the REC and the tech 2 session ,did you fit the trailer module ?
    pic borrowed from Migweb
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    Had the same problem last week the module above was missing from mine too!
    Vauxhall wanted £69 for the above part local scrapers did it or £18 inc VAT!
    Feb 2007
    Cheshire
    Ah right. Now I've never seen one of those before and certainly not in the kit I bought. Where does that fit?
    Apr 2011
    EMEC #3
    If you take the boot lining off on the left hand side there should be an empty space at the right hand side (as you look in there) this space will either be empty looks like another connection block sould go there, or if the above is connected a trip to Vauxhall maybe required to diagnose the issue.
    (Also ensure that number (13 iirc) fuse is fitted with correct ampage fuse too as this is for the trailer lights too).
    I would take pictures for you now but im at work unfortunately mate.
    Apr 2011
    EMEC #3
    Here's the back of the unit that is required if missing.
    Just found it on my phone.
    Feb 2007
    Cheshire
    Thank you for your help. It would appear that the chap I bought the kit off has left this plugged in his motor.
    I shall start ringing dealers and scrappys on Monday!
    Thanks again
    Apr 2011
    EMEC #3
    no worries I know my scrappers had another couple in if your struggling give me a shout i'll see what i can do for you mate.
    Feb 2007
    Cheshire
    Brilliant. I dont suppose you know the part number do you?
    I pick a new caravan up on tuesday!!
    And thank you for the offer, could be a life saver. Where is the scrappy?
  1. Towing electrics without the v/x kit
    By crgv6 in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2010, 18:40
  2. towing electrics and op com
    By winnie2457 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 12:13
  3. towing electrics
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2009, 20:27
  4. Towing electrics kit
    By ally1873 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2007, 23:35
2008 vectra towbar electrical module
opel vectra c trailer module
