Thread: Passanger and rear electrical windows don't work
    Aug 2012
    T
    Default Passanger and rear electrical windows don't work
    Hi
    Both rear and passenger window worked one week ago but now they don't. When using drivers switch all windows work fine.
    I tried with windows lock on/off but nothing.
    Are there any other ways these switches are blocked?
    Thanks in advance!
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    just a daft question are you sure the slider is set to the rear window when trying it from the drivers door switch as that once happened to me and i thought mine were knackered
    Aug 2012
    T
    Quote Originally Posted by neverlandandy View Post
    Driver's door switch is working fine, except that rear left window doesn't work with driver's switch. All other windows work fine with it.
    Situation:
    1. With drivers switch all windows work except one rear window.
    2. Passenger window doesn't work with passenger switch and same with the rear one's.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    this seems to be a common fault with the passenger side switch, it can just stop working, i had this problem my self with the passenger switch, did not have rear electric so cant comment on them.
    the switch is faulty, you can remove it (carefully) and try to clean the contacts etc with the correct type of cleaner and see if that fixes it, if not then ebay for window swicthes, im quite confident its the switches at fault and not any other problems, out of interest does your passenger door speaker and mirror still work?
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    check the door loom , mate had this on hes elite !
    Aug 2012
    T
    Quote Originally Posted by 06sri View Post
    I am going to clean the contacts, what you suggest for cleaning? Will vodka 40% will do the work?
    Speakers and mirror are working for passanger side but rear tweeters and 1 speaker don't work.
    Aug 2012
    T
    Quote Originally Posted by biffbangpow View Post
    Did he check for wires not been damaged?
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    Quote Originally Posted by matt89 View Post
    yes , and they were several broken ones , pull the rubber boot out the door and inspect the wires
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    several would be an understatement , only had 3 that weren't broken on my o/s/r door , had 4 broken on n/s/r door .
    was also getting the check safeguard messages on the dash up until I repaired both sides .
  1. Replies: 13
    Last Post: 11th December 2010, 23:37
  2. Does Insignia Windows Operation via Keyfob still work ?
    By 67688c in forum Insignia car chat
    Last Post: 31st May 2009, 15:35
  3. Rear electrical centre
    By Geoshaw in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2006, 23:48
