Thread: Possible ECU problem
    Nov 2010
    yorkshire
    Default Possible ECU problem
    Hi guys, need some help please.
    I have a 56 plate Sri Vectra 2.2 Direct petrol. It broke down last week whilst on holiday when the "spanner in the car" came on and it suffered loss of power and wouldnt rev above 3500 rpm. The recovery agent said it was the air flow / mass sensor that was the problem. He cleared the fault and i was on my way. As a precaution i had it to the local garage where they replaced the part. It then flagged up a problem with the crank and cam sensors. These were also replaced but it still wouldnt rev. After a week in the garage, they decided that it might be the ECU and a replacement was £1500 - £1800. The swirl flaps were also mentioned. Needless to say i had to come home via AA recovery.
    Having spoken to a few people i am now at a loss as to which direction to go next. I have been given the following advice;
    Disconnect battery for a minimum 12 hrs then re connect and the ECU might re boot.
    Buy a second hand ECU from Ebay.
    Send my original to a "specialist" and get it repaired, or send it to Vauxhall and get ripped off.
    has anyone had a similar problem and could help or offer me some advice.
    Thanks.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try getting them to reset ecu an install the latest software
    Nov 2010
    yorkshire
    Thanks for that "Critch", had it to the garage and they say its the swirl flaps. They have a mod they can fit and they "reset" the ECU as a matter of course.
    £525 for the original diagnosis, parts, labour + re-set but at least the car is mobile again and fingers crossed, no problems.. Cheers..
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Carnt see the ecu being the problem tbh them simtec 81.1 ecus are bomb proof they ain't even a full ecu just a partial one just for the bits needed
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Sounds like the mod is clean the inlet an weld them open lol
    Seriosly I'm not sure they would want to "reset" an ecu as matter of course :/
    Hope it sorted at least
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
vectra c ecu problem
