Thread: Front wheel movement
    swansea
    Default Front wheel movement
    There is play in both front wheels when moved side to side, no play when held top and bottom. This is with wheels off the floor. Bearings or balljoint?
    South east
    With worn bearings you usually hear a grumbling noise.
    Regular Member Keif's Avatar
    In the Garage
    First place to look is the track rod ends.
    Could also be wishbone bushes, you'll see better if you turn the steering onto full lock so you can see the track rod end when you wobble the wheel.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I had the same issue as you describe just before my MOT at the end of July. I was worried it would fail, but was pleased (if pleased is the right word!) with just an advisory that there was minor play in the track rod ends, which i was originally advised about at the cars 1st MOT back in 2007! Those were the only advisories i have had for that problem in 6 MOT's.
  1. Rear wheel movement at the top
    By jacko52 in forum Suspension, Wheels & Brakes
    Last Post: 7th January 2012, 19:49
  2. Low front end and movement in suspension when braking
    By Mrmac in forum Suspension, Wheels & Brakes
    Last Post: 3rd November 2011, 17:52
  3. Movement when I hold front n/s wheel at 3 and 9 o'clock and rock
    By sheepish in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2010, 23:01
  4. Steering wheel movement
    By kinger in forum Handling & Braking
    Last Post: 2nd August 2009, 18:11
  5. rear wheel movement and noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 5th August 2008, 12:37
