Thread: colour screen, straight swap???
    Vectra-C Extreme Poster Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Default colour screen, straight swap???
    Hi guys i had a cd30 with plain screen now have an aftermarket dvd unit fitted but just wanted to add a colour screen is it straight swap will it work??
    Also how much should i expect to pay
    Many thanks
    Stu
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you get a unit that is unpaired from its head unit or get the car pass for the doner car then its straight forward as it will need Tech 2'ing in make sure you get one for the facelift i.e. one that is for CDC series the earlier ones won't work I believe, as for getting hold of one it might be easier to buy a complete CDC70 set up and selling on the HU and your old display as they don't come up that often.
    Jul 2011
    UK
    Year : 06
    I maybe wrong but am pretty sure it's plug and play
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Not on the CDC range unles you have a divorced display or car pass, the displays are paired to the HU if you put both in it is a straight swap or if you have a half can one but that doesn't work with the CDC range
    Jul 2011
    UK
    Year : 06
    Ah I see just wonderd as when my mate got a cd30 with screen he wasn't sure if the screen was working so I plugged it into my car with aftermarket head unit and it worked
    Regular Member larrygroke's Avatar
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    it is plug and play i want to do this however with last min deployments cropping up im unable to do this but it is a stright swap but you will need the smaller air vents as the screen is slightly wider
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    So explain how the car pass system works then the displays are coded with the HU to each other and need to be divorced or put in as a pair the half can just swap over be interested if this not the case but I don't actually believe it does.
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    Big Red. I have a screen with the appropriate vents for sale. Drop me a pm if you want to discuss a price?
    It will be plug and play with a full can vec and aftermarket unit.
    The pairing system works because it is to deter the hu from being stolen. Assuming no-one will steal the screen as well. So the process stops the hu being added to another screen with the coding system lying within the hu rather than the screen. So when you add an after market unit there is no coding issue.
  1. Tps straight swap?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 14th February 2012, 18:57
  2. Been offered a straight swap on my vec, what do you think?
    By sri andy in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 11:05
  3. Swap mono screen for colour in Signum
    By peterc2609 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 13:30
  4. are these a straight swap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 18:43
