Results 1 to 3 of 3
Thread: How easy to swap tailgate?
    May 2012
    UK
    Default How easy to swap tailgate?
    Anyone have any insight into how easy it is to swap a tailgate over on a Vec C facelift?
    Aug 2010
    Leeds
    I expect 4 bots 2 per hinge and then the struts to remove pull down head lining.
    Regular Member Keif's Avatar
    In the Garage
    If it's the same as a Signum, the biggest issue is your wiring. You'll need to disconnect it and pass it through the hole in the body work.
    As for the tailgate. Just remove gas struts. Remove the retaining clips on the end of the hinge pins, and knock them out. Lift away fromth car.
  1. NCDC2013 Sat Nav Swap easy or hard?
    By jonnybobs in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2011, 22:16
  2. Rear Lenses swap!!!! easy or not???
    By bigb1983 in forum Bodywork & Interior
    Last Post: 11th June 2009, 16:11
  3. Tailgate Struts for Signum - Easy Fit?
    By spj555 in forum Bodywork & Interior
    Last Post: 10th February 2009, 23:51
  4. front end swap - how easy???
    By m_r_shaw in forum Bodywork & Interior
    Last Post: 4th February 2008, 22:31
  5. is it easy?? CD30 and CDC40 swap
    By andypolo in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2006, 23:11
is it easy to swap a tailgate
