Results 1 to 10 of 13
Thread: Y20DTH Boost Sensor
    Jan 2008
    stockport
    Default Y20DTH Boost Sensor
    Was going to give the boost sensor a clean over the weekend, and looking at it's location in the Y20DTH, it seems to be a pretty tight fit.
    Is is possible to remove it without removing the throttle body? or is it just as simple to remove the throttle body and clean both?
    Thanks for any help
    Colin
    exeter
    look on the how 2 and look for cleaning inlet manifold and egr valve for a 2.2dti . you might as well do this aswell it really does make a difference .
    Jan 2008
    stockport
    I've seen the how 2 on the inlet manifold, but to be honest, I think it's a bit beyond my DIY abilities at the moment; but the boost sensor seemed a more simple job to attempt.
    I may well end up taking it into the garage to have the inlet manifold done. If i take the throttle body off it should give me some idea how much carbon build up there actually is; the car is on 115K, (90% motorway) miles so there should be a fair bit by now.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    its not as hard as you think , even just do the throttle body,boost sensor and egr valve
    but to answer your Q use a 8mm ring spanner and you can get the sensor out ok
    Jan 2008
    stockport
    Ok thanks for that peadar.
    exeter
    i thought that when i first saw it but i was'nt going to pay a garage money for doing it . it took me 45 minutes when i done it and the car is so much more poke . dont be affaid to do it. the hardest job is pumping the fuel back but if you do it how they say. it easy and does work
    Jan 2008
    stockport
    Well I've ended up just doing the throttle body and boost sensor today. Tbh the boost sensor wasn't that bad at all, much better than I was expecting.
    The throttle body did however have quite a good layer of carbon build up on it. I've attached pictures to show the condition of the throttle body and inlet manifold.
    After getting to see the inlet manifold, with the throttle body removed; I can appreciate what you're saying. It is just the thought of screwing something up and the fuel priming, that's holding me back a bit. I'll keep reading and get round to giving it a shot. I'm sure if I'm struggling, this great forum will be able to offer some advice.
    One things for damn sure, I won't make the same mistake as today and leave oily footprints across the carpet in the house - this missus was not impressed!!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    that looks fairly well coked up , mine was a right old mess when I cleaned it all out , think it was on 176k miles at the time
    surprising just how much difference it makes , be sure to give the EGR valve a good clean out as well , remove the grey plastic cap from the end of the EGR & there is a cam mechanism inside that gets full of carbon , this also needs to be cleaned .
    Jan 2008
    stockport
    EGR is next on the list of things to do, hopefully it will be easy to remove, I've heard of some people struggling to remove it. Then I may well tackle the inlet manifold.
    One thing I did notice with the throttle body off is some damp areas behind the silicon pipes (that I think are the leak off pipes) highlighted in the photo, does that mean I should be getting those changed out as well? and if so, is it an easy enough job to do on the 2.0DTI.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Probably leak of pipes need replacing mate helps alot with startin the car up once changed
  1. 2.0DTI Y20DTH Crankshaft Sensor & Metal Shavings
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:15
  2. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  3. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
y20dth boost
vectra c 2.0 dti boost sensor cleaning
