Thread: squeak when turning left
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default squeak when turning left
    Got a problem with my car I have a sort of squeak coming from my left front wheel. When I'm not moving and I turn the wheel there is no noise but soon as I'm turning left when moving its back any ideas on what it could be. I've tried pressing the breaks but it don't go away when I press. Any ideas
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    i have a squeak on the left too but i think its the top strut braring again . wd40 didi the trick last time
    May 2012
    chelmsford
    rust on the disc edge, when turning it catches and makes the noise. when turning right it should stop. should go after a day or two driving or take wheel of and go round the edge with a wire brush. i have found that many times hth
    Oct 2009
    Sandwell
    It does go away when I turn right. I've had it for about 2 weeks now ill take the wheel off and wire brush it see if that helps
    May 2006
    scotland
    It could be the heat shield at the bottom inside of the brake disc rubbing on the brake disc as the wheel rotates. I had this very problem.
    With car parked on the road, wheel on and in the straight ahead position, lying flat on the ground, I put my arm around the back of the offending wheel and fumbled about until I found the inside of the disc and noted that the heat shield was resting against the disc. I then did the same with the other front wheel and noted there was an air gap between the heat shield and brake disc.
    I simply prised the offending shield out slightly with a screwdriver and no more squeaking\squeeling as I drive.
  1. Noise from F/O/S wheel when turning left
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 23:24
  2. squeak sound when turning left and right
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 22:17
  3. Chirping noise when turning left
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:50
  4. Cold Turning Left
    Last Post: 9th January 2009, 21:38
  5. vibrating noise when turning left/right
    By valhalla in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2008, 21:55
vauxhall vectra squeaking when turning
opel insignia squeel out off front wheel when turning right
vectra c squeak turning left
vectra squeek when turning
vectra c front wheel squeaking
vauxhall meriva squeak on turning left
vectra c squeaking when turning right
vectra c sqeeking when turning right
Vauxhall Astra 2009 plate squeaking when turning left
squeaky insignia on left turns
vauxhall insignia front wheel squeak
