Thread: Air con blowing out warm air
    Sep 2011
    Northern Ireland
    Default Air con blowing out warm air
    My 2007 vectra air con is blowing out warm air. Will a re gas sort it out or is it likely to be more than that?
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Impossible to say really.
    Did it suddenly stop working or has it just faded over time?
    At tickover do the revs drop slightly when you switch on the AC ?
    Could be a leak from hoses, a failed compressor or a stone damaged condenser, (the radiator like thing that sits in front of the main radiator.)
    Or it could, as you say, just need a re-gas.
    There are several threads on the subject on this forum.
    Do you use it regularly, or only when the sun comes out?
    Sorry if you already know this but AC is for all year round use, not just for hot days. The rubber seals can leak if not used regularly and the refrigerant can leak out.
    It also makes for an excellent demister in winter when used in conjunction with the heater.
    Sep 2011
    Northern Ireland
    I honestly never knew it was all year round use. I would just use it when it's warm. And I got it back in November so never really needed it till recently. Although I know it did work when I got it. Just doesn't now.
    Just have to take it to experts then.
    Nov 2009
    newcastle
    Take to a decent place and tell them. Get them to gas with a dye which if it leaks shows where the problem is. Usually £40-50 If I remember right. Independents that specialise prob best. Lots of garages bought the kits because it's easy to recharge and make a few quid. But not many that understand fully. You can even buy a regas kit but id say go garage.
    Full Member Big Sig's Avatar
    Quote Originally Posted by geordieric View Post
    If they do it correctly it will be vacuumed out first. If the system doesn't hold a vacuum then they need to dye it etc.
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Go to Kwik Fit mate. Got mine done a couple of weeks ago as the wife never has it turned on and when I went to use it only hot air was blown out. Took it to Kwik Fit, they vac'd it down and regassed it and pressure tested it. It was empty as they hardly recovered anything. It held the new charge but when he tested it it was still blowing hot air out so they never charged me. Driving off I decided to check again and noticed he hadn't turned it on via the computer. I turned it on and hey presto, penguin temperature.
    They charge £49.99 for a recharge and if it doesn't work it's free. Other places will be cheaper but you will still pay even if it doesn't work.
    Jul 2012
    scarborough
    Quote Originally Posted by pompey-pimp View Post
    My air con wasn't working so I took it to a garage this morning, there was very little refrigerant in the system so what was remaining was emptied and fresh put in. But still my air con doesn't work, the compressor isn't kicking in, I've checked all the fuses and everything seems ok but you mention turning it on with a computer how do I do this?
    Quote Originally Posted by burbling1 View Post
    Only applicable with climate control.
    With bog standard AC, you just press the snowflake button to turn on/off, but with climate you need to turn off ECO mode in the climate menu for the AC to start working.
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
  1. blowing warm not hot
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2011, 20:47
  2. Replies: 1
    Last Post: 28th September 2011, 21:57
  3. Vectra c heater prob only blowing warm help
    By 0114NIGEL0114 in forum Troubleshooting
    Last Post: 3rd January 2011, 17:03
  4. blowing look warm air
    Last Post: 24th December 2010, 16:07
  5. heater blowing warm
    Last Post: 3rd December 2010, 17:09
vauxhall insignia blowing hot air
vectra c air con warm
climate control is only blowing hot air on my insignia
air con on vectra blowing warm air out
vauxhall vectra air con blowing hot
o5 vectra blowing warm air when on full
vectra c air con blowing hot air
vauxhall corsa life air con blowing hot air
vauxhall vectra air conditioning hot
where is the on off button on a insignia climate control on off button site:www.vectra-c.com
air conditioning on vauxhall insignia blowing hot air
vectra c air con blowing warm air
vauxhall vectra only blowing warm air
