Thread: Estate rear anti roll bushes
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Estate rear anti roll bushes
    An someone help with which ones i need as i found many with different sizes but need correct one for vectra c estate 06 plate?
    South east
    There's no way to know just from the age, bodyshape or even the engine. To be certain, you need to read the size written on the side of the bush (and hope it's fitted with the writing on the outside). Failing that, buy both sizes (they're cheap) look at the old bush after removal and fit the correct new one, and return the unwanted size.
    Nov 2009
    newcastle
    As rebellion said no sure way. I did mine few months ago and bought 2 diff sizes and matched up when removed. They only cost 78p each if I remember right so no hassle. I would reccomend dealer tho to make sure not poor rubber.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Thanks guys. As one have slight of play and can feel slight clicking from rear so know it need replace as soon as!
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Could be rear shackles or upper control arms
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    No, anti roll bushes is the source from mot test
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Jack the back of the car up, put it on axle stands, get underneath and read the part numbers off the bushes. It's the only way to be sure as others have said fella.
  1. Rear Anti Roll Bar Bushes
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 22:45
