Thread: Veccy C P0354
    north west
    Default Veccy C P0354
    Hi,
    I wonder if someone can just clarify what i think might be the problem with my Vectra 2003 1.8 ls.
    Today it was running fine then this afternoon i went to drive it and it was misfiring and sounded very lumpy.
    I then connected my op-com that came back with
    P0354 - Ignition Coil Cylinder 4 Circuit Range/Performance
    (08) - Present
    I`m presuming this is the coil pack so took it off and checked the nearby connectors.
    This seemed to fixed so i turned it off and cleared the fault.
    However after 10mins when i tried to start it again i was back to square one again.
    Are there any Vectra gurus that think the same as me being the coil pack?
    Thanks for any help
    wirral
    58 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Coil pack going open circuit once hot.
    You can confirm fault by testing coil using op com via engine diagnostic actuator tests
    north west
    Cheers mate, trouble is i am bit of a novice with op-com but will have a look thanks.
    wirral
    58 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Fairly easy
    engine ( make sure you click on tight engine code)
    Then should come up with list
    should she actuators
    then in their is coil test
    Well that's their or their snouts from memory how tech2 is so should be same
    north west
    I dont think this is the same, ive found ignition coil cylinder 1,2,3,4 all seperate test not sure how to use it, say connect test spark plug.
    This morning i took off the coil pack and clean the springs that connect to spark plugs, number 4 was abit gummy car started ok but when it got to temperature it came up with the same cylinder 4 coil error.
    wirral
    58 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Just put spark plugs in coil an place against engine an activate test
    Should a see a spark if it ok
    north west
    Thanks for your help Critch, decided to get a new coil pack, after bringing it up to temp and a drive around seems to be fixed. fingers crossed
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  3. Veccy may have to go
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 22:51
  4. Veccy C to replace Veccy B?
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 08:49
  5. V6 Veccy-B to Oil fired Veccy-C
    By Alpha10 in forum Introduce yourself.
    Last Post: 8th February 2006, 09:22
vectra c p0354
engine code vectra 03 p0354
