Thread: Black smoke after Egr valve cleaning
    Regular Member glasgowdarren's Avatar
    glasgow
    Default Black smoke after Egr valve cleaning
    I cleaned my egr valve and the boost sensor the other on my vectra 1.9 120. The power has returned but now I'm getting black smokey exhaust when going over 3000 rpm and sometime getting bunny hopping, can anyone help ?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Probably just the disturbed carbon and carb cleaner burning off...
    glasgow
    Quote Originally Posted by Chunklamb View Post
    this is something I thought it might be, so if I kept it at 2000-3000 rpms and burn the rest out would this help ?
    Jan 2012
    Milton keynes
    Mileage : 38100
    I've just mine today, I used a whole can of carb cleaner on mine, had a bit of lumpy idle or when held at revs... all back to normal after a 10 minute drive or so.
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    the italian tuneup is you friend mate, get it nice and warm and take it for an arseing, will soon clear itself through, if it doesnt then there is an issue but that isnt really likely
    South East Region ARO And Resident Diesel Head
    Owns: 2005 Vectra Life Hatchback 1.9 CDTI 150 Mods: Too Many !!!
    glasgow
    Took it for drive on motorway not so black as more grey smoke when in high gear below 3000 rpms, I did try to boot the arse out it to burn any soot that I missed.
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    does it mifire when its doing it ?
    glasgow
    No not at all, was running at normal apart from the smokey exhaust
    Nov 2009
    newcastle
    Don't think you have but you aint got a dpf by any chance on it?? (I had bother with mine)
    Even if you don't prob as others say crap caught in the system inc cat & exhaust.
    Put a cat cleaner in the tank when fuel low and will help clean up. If you had a large amount of oil/soot in will be clagging up the system and needs bit extra help.
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    well if i was a major problem you would feel it and it would miss, i could even be residue of the cleaner, etc or even oil washed into the exhaust, drive it for a bit and see if it improves
  1. Help cleaning EGR valve!
    By Vectra_Power in forum Diesel Engine related
    Last Post: 23rd November 2009, 10:28
  2. Help cleaning EGR valve
    By eraser2002 in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 11:54
  3. Cleaning EGR valve ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 8th January 2008, 09:33
black smoke from vectra after cleaning egr valve
how long to clear black smoke after egr clean
vauxhall zafira smoking after egr change
cleaned egr valve still smoking vauxhall
s320 black smoke after egr clear
vectra c black smoke from exhaust after using fuel cleaner
black smoke still after changing the egr.valve
egr valve cleaning after black smoke why
