Results 1 to 2 of 2
Thread: 2.0 DTi - Vibrating Auxiliary belt after changing.
    Midlands
    Default 2.0 DTi - Vibrating Auxiliary belt after changing.
    Evening.
    Hoping someone might be able to help.
    I recently changed the bottom pulley on my 52 plate 2.0 DTi as it decided to break into two!
    After wasting a lot of time on a VERY tight bottom pulley bolt I've assembled everything back together. However, a couple of seconds after starting up, a vibrating noise has become very obvious. It starts about 4 seconds after initial startup once the engine settles down to idle speed. If I look around the auxiliary belt area, it looks like the problem is that the belt damper / tensioner is vibrating a lot and not really doing it's job. Could I have put something back together wrong or could it be a faulty damper? There is still a lot of tension in the spring loaded damper as it was a bit of a task to get the belt back on!
    As the belt had come off when the bottom pulley went, I didn't have to undo anything to get the belt off, so all I did when I refitted it, was to pop a ratchet onto the nut move the tensioner in the way of the damper to give me slack space to put the belt on. Once the belt was on, I just took off the ratchet. Is there anything else to tighten up?
    Thanks anyone for help.
    Nottinghamshire
    Was it a genuine pulley (and bolt) you fitted? Some of the aftermarket ones are the wrong weight and/or not balanced so cause more vibrations instead of damping existing ones out.
  1. Replies: 28
    Last Post: 22nd April 2014, 22:56
  2. 2.2 DTI Auxiliary belt diagram
    By MelHook in forum Engine & Drivetrain
    Last Post: 7th April 2012, 13:33
  3. Best way to change the Auxiliary belt
    By FrenchConnection67 in forum Troubleshooting
    Last Post: 5th March 2012, 19:43
  4. Auxiliary Belt Y20DTH?
    By Thom in forum Engine & Drivetrain
    Last Post: 14th September 2011, 18:29
  5. Auxiliary belt
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 20:20
auxilary belt vibrates vectra c
