Results 1 to 10 of 17
Thread: Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    Aug 2012
    Blackpool
    Default Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    Hi All,
    Wheni turn my car to ignition i get alot of lights showing up, traction control, ABS, handbrake warning, glow plugs, and the engine light, but theres no spanner light.
    I see this is an important lamp, and i'm asking if my model has one (as the manual is a bit generic, covering all Signums or all trim specs and engines) or should it just have the engine light.
    I guess if it should have one, and i haven't, i've either got a blown bulb (unlikely) or a dodgy seller has removed it (Likely)
    Its a 2004 Signum Elite 1.9CDTI 150, prefacelift
    Matt
    May 2011
    bispham, blackpool
    Quote Originally Posted by StreetDragster View Post
    Hi All,
    Matt
    if you want i can put your car on the laptop to see if you do have any faults or old faults and clear them i only live in bispham.
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Nope the spanner does not light up on ignition.
    Nov 2009
    newcastle
    You Only get the light on display at start up if the ECU thinks something wrong cold. Depends on the software level lots of faults are not on the software so it doesn't know what to do with them bar possibly a light at start up. For example early ones wernt listed with maf and dpf faults so it says no fault or a generic code cos it didn't know. Supposedly vx hav sorted but you would have to buy the update from vx . Get the system checked anyway and see how old software is at worst.
    Everytime I change cars I also ring vx customer care and check it hasn't missed any recalls or updates. 2min phone call
    No spanner is a good thing
    Aug 2012
    Blackpool
    Thanks All, seems i'll not worry too much just yet.
    Can a instrument cluster test/dial sweep be completed with the Op-Com tool?
    Matt
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    On ignition, all yellow warning lights light up then all except the yellow emissions light go out.
    Aug 2012
    Blackpool
    Quote Originally Posted by john_k_sri View Post
    Are you saying i should be seeing the spanner light illuminate, and then go out?
    Matt
    Liverpool
    I think there is confusion as to what you mean by spanner light.
    The car with a spanner is a fault on the car
    The oil can with the spanner is the service light and does not always come on. Only when needed.
    Which of these pics shows the light you are talking about ?
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Matt
    Yes, I believe it's part of some sort of diagnostic procedure triggered at ignition. The emissions light (engine symbol) will stay on and should extinguish on starting the engine, all other yellow lights should go out before starting the engine.
    The 'car and oilcan' light was dropped on the facelift, it indicates 'service due', on the facelift 'service due' is indicated by 'INSP' in the odometer.
    May 2011
    bispham, blackpool
    Your messages are full
    Sent from my HTC Wildfire using Forum Runner
    By Shadrack in forum Troubleshooting
  2. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  3. 2.0 DTI engine spanner light?
    By Thom in forum Engine & Drivetrain
    Last Post: 5th August 2011, 22:51
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
vectra car door with spanner light
2.0dti spanner light and traction control light on and loss of power
