Results 1 to 10 of 21
Thread: Lack of power
    West Midlands
    Default Lack of power
    I've got a 56plate Vectra CDTI 150 Elite, since I've bought the car, it seems to have no low down power, and black smoke when the turbo kicks in, and then it's goes like the wind. Thought it could be the EGR took it off, and it doesn't look that old and the plunger moves freely, put a blanking plate over it as well though (£3.99 off ebay with four holes in to stop the EML coming on), changed the boost pipes to silicon ones. Swirl flaps are fine. No fault codes coming up. Only thing I'm wondering that could be causing an issue is the DMF needs changing (Booked in for next friday). Would that make me lose power bottom end?
    Regular Member amand's Avatar
    Feb 2011
    west London
    Could be throttle body. Try spraying some carb cleaner down it, my help free it up a bit.
    Jan 2012
    Gloucestershire
    Black smoke is unburnt fuel, so either too much fuel, not enough air or fuel at the wrong time.
    Still sounds like an EGR. Have you unplugged it? You will get the eml, but just because the EGR is new and not sooted up doesn't mean the electrics to it are working properly. Would have thought the blanking plate would have helped though. Try blanking entirely with a home-made plate too.
    Feb 2011
    west London
    could also be your Mass airflow sensor.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You should have tried blanking the EGR completely, by using the one with the holes you still can't rule out the EGR.
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Do this...
    West Midlands
    Cheers guys, will fabricate something tomorrow and blank it off completely. Ta
    West Midlands
    Ok, pretty sure it's not EGR related. After doing some investigation found the swirl bar lying on top of the manifold. Did the mod with the washers from B&Q. Took the car out and after 50yrds the EML came on and it went into limp mode, restarted it, flew up the road and the car went like stink, till it went into limp mode again. Bar 1 & 2 seem a little stiff, but judging from how long the bar looked like it had been lying there I put it down to lack of use. Anyway they now don't sit there as tight as they originally did or operate like they initially did. Am I looking at a new inlet manifold or are there any other fixes?
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    hi m8 your next stage is to bond them open and i still have a tube of liquid metal from when i done mine you can do yours with it if you want save buying a tube let me know n i'll drop it round to you as i'm only litrally round the corner n also i have opcom if you need it buddy just give us the nod
    gaz
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    hi m8 your next stage is to bond them open and i still have a tube of liquid metal from when i done mine you can do yours with it if you want save buying a tube let me know n i'll drop it round to you as i'm only litrally round the corner n also i have opcom if you need it buddy just give us the nod.
    gaz
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 11:51
  3. lack of power
    Last Post: 6th February 2011, 20:18
  4. Lack of power...
    By lightfx in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:33
  5. Lack of Power
    By juggernaut in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 16:20
