Results 1 to 10 of 16
Thread: 1.9 CDTI 150 Intermittent Stalling When Running
    Aug 2012
    Blackpool
    Default 1.9 CDTI 150 Intermittent Stalling When Running
    Hi All,
    Apologise if this is an obvious question, but I'm new to Vauxhall's and my symptoms do not appear to match the 'common' symptoms of 'common' faults, so please bear with me.
    2004 Signum 1.9 CDTi 150 (85k Miles)
    I have just picked the car up, so not a great deal of time to test, but what happened was I picked the car up and drove slowly to the motorway, all fine, then 30 mins on the motorway, again all fine, came off the motorway and on a 50mph road on part throttle/boost the revs just decayed and then the engine stalled.
    Pull over, it immediately restarts and drives ok, I put my foot hard down and the boost builds, then it seems to stutter/miss fire, then the revs decay again and then it stalls.
    It immediately restarts and then I'm able to drive it home without issue (but not using much throttle) for the next 20 mins.
    As a side note, for a 150bhp car, I think its under powered.
    I have no engine management or other lights on, I have Op-Com in the post but its not arrived yet.
    I'm aware of the common CDTI problems and I intend to check/rectify all of them-
    Swirl Rod/Bars
    Small Boost Pipes Near Front Right of the engine cover
    EGR Stuck/Clogged
    Throttle Body Clogged
    Boost Sensor Clogged
    I guess my question is, are the symptoms I'm seeing possibly attributable to one of the common problems listed above (and if so, which one?), or is it possibly something else, and if so, what?
    Thanks In Advance
    Matt
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    pop over to mine saturday fella will get it on the tech 2 for you and get it sorted out mate if u lkike
    Aug 2012
    Blackpool
    That is very kind of you Paul, i'll see how i'm fixed for jobs on Saturday and i might just do that.
    Thanks again for the offer
    Matt
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    no bother mate another member will be here aswell drop me a pm if ya wanna pop over i will give you my adress
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Throttle position sensor in the throttle body housing. The solder joints will have dried out and cracked. Resolder and symptoms should disappear.
    Insignia VX-Line Nav CDTI 170.
    Aug 2012
    Blackpool
    Thanks Gaz, i'll look into that aswell. Seems it may be related to the common problems, so i'll get them out the way first.
    A further development is that this morning, whilst sat at traffic lights idling, it dropped its revs twice, didn't stall, but still wasn't happy. That said though it behaved itself throughout the rest of the drive.
    Paul, i'll drop you a PM now
    Matt
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    this maybe of interest to you
    click below
    http://www.vectra-c.com/forum/showth...osition+sensor
    Aug 2012
    Blackpool
    Very helpful, thanks, certainly seems like a possible suspect. I'll look into it, and i may even do the injector harnesses as a matter of course.
    Matt
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    if the 3rd injector is yellow then its the old one
    blue is the new upgrade version
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    sorry if you have allready seen this thread
    http://www.vectra-c.com/forum/showth...gine-read-this
  1. Vectra 3.2 V6 intermittent running fault
    By riddy in forum Troubleshooting
    Last Post: 26th June 2012, 09:23
  2. 2.0Dti (Y20DTH) almost stalling - intermittent
    By MatB in forum Engine & Drivetrain
    Last Post: 7th June 2011, 17:45
  3. CDTi 150 intermittent running problems
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 14:13
  4. 1.9 CDTi intermittent stalling
    By iRocco in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 09:09
  5. 1.9 CDTI stalling
    By OilBurner in forum Engine & Drivetrain
    Last Post: 19th January 2007, 14:09
