Results 1 to 10 of 13
Thread: Poorly Cdti V6
    Regular Member Mick B's Avatar
    North East
    Default Poorly Cdti V6
    Hi chaps need a little help my 05 plate diesel V6 3.0 auto has gone into limp mode a few times over the past month. It is always when accelerating cold within the first 5 minutes if you a push the car hard ie joining a motorway slip road. Once in limp mode (spanner on the dash)the car struggles to get 30 mph but the problem goes away if the ignition is off for a few minutes. The car can be ok accelerating for a few weeks and gives no indication it has a fault till this point.
    I have used a code reader and it has come up with a code
    C3800 any ideas.
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    I thought all codes were 1 letter 4 numbers?
    North East
    Quote Originally Posted by BigWilko View Post
    Thats what I thought. The only other code stored was P0000
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    North East
    Can't find anything on the link
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    All codes are on the thread but the ones you have aren't there. I presume you did the pedal test? I think 0000 might just be the light flashing out, as in, no code?
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    7 Post(s)
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    is it just me or is c 3800 not indeed one letter four numbers?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Ha Ha Ha, yeah. I guess it got edited in the time it took me to type my first reply maybe?
    Cumbernauld, Scotland
    Your car probably struggles to get to 30mph as it is an Automatic transmission
    I have a similar problem when Safe Mode is applied on mine, but the car does at least still accelerate albeit the revs are higher than I would normally use
    I suspect this is the early signs of EGR failure, very similar symptoms to mine at the end of last year with erratic Safe Mode when accelerating hard, especially when the engine was cold
    Regular Member mattv6diesel's Avatar
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    Mine did the same sounds like sticking turbo veins
  1. 1.9 16v cdti sometimes starts very poorly when warm help plz?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 13:55
  2. Poorly 1.9 CDTi
    By chockymonster in forum Engine & Drivetrain
    Last Post: 5th January 2011, 20:15
  3. Is it poorly?....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:22
  4. My pc is poorly
    By ion in forum General Chat
    Last Post: 7th February 2007, 11:53
  5. Poorly
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2006, 15:39
