Results 1 to 10 of 21
Thread: cant get an brake fluig to rear nereside caliper
    Cannock
    Default cant get an brake fluig to rear nereside caliper
    I changed the pads in my 1.9 diesel vectra 2005,everything was ok until I come to bleed them.I cant get any fluid to come out of the rear n/s cylinder altough it comes out of the o/s,
    They had started to feel spongy and the pedel loosing pressure before I chanded them
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you got a brake pipe clip/vice?..I would clip the line closed and remove the bleed nipple from the caliper. Clean it through and put back in place..maybe even unclip the line and see if fluid flows.....
    Cannock
    hallo nicroc
    I have done that and taken off the hose but to no avail,cant understand why it bleeds on the nearside and not a drop from the n/s
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    dID FLUID COME THROUGH THE OPEN CALIPER(WITHOUT THE BLEED NIPPLE IN'??
    Cannock
    no it did'nd nor with the pipe completly off,not a drop,if it was a slave/master cylinder why will it bleed 3 out 4 wheels
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Air lock maybe?...did you use an ezibleed pressurised system or a pump the peddle and release the bleed nipple approach?..ezibleed for me,runs off air pressure from the spare tyre so is a forced system,
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    did the fronts bleed ok?..i bleed opposite corners..
    Cannock
    hallo again
    to be honest i only bled backs,well 1 of them and I used an easibleed off a tyre,I'll try again tomorrow,I was thinking about the abs unit where the pipes come from,could there be a fault with that
    thanks
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I believe that the braking system is effectively split into two seperate systems,why i bleed opposite corners/diagonals.,This is a safety system ,should one fail the other compensates.One time me and my brother struggled with a similar problem..turned out the pump had failed.simple fix..when we knew what was broke.
    Cannock
    thanks i'ff to the pub for a quick pint,I think after the day i've had I deserve one.I'll post again tomorrow with any updates
    thanks again
    reg
  1. Rear brake Caliper
    By scoles1 in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 23:16
  2. Rear brake caliper
    By NI-2.2SRI in forum Handling & Braking
    Last Post: 16th March 2009, 19:33
  3. rear brake caliper
    By jerc in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2007, 13:56
