Results 1 to 10 of 11
Thread: Ford Ka - hot air coming from vents on all settings
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Default Ford Ka - hot air coming from vents on all settings
    My ole mum has one of these Ford Ka things.. Its a pile of you know what but its hers and i am now charged with keeping it running...
    Its an 05 plate with a 1.3 engine.. Its basic and does not have a temp gauge on the dash. In the cabin the blowers only blow out hot air. I topped the coolant up a week ago and it has not gone down since... I can hold the throttle open and get the fan to kick in.
    Does anybody have any ideas as to what the cause of this hot air on all the cold settings could be? Is it the thermostat?
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    she hasn't got it set on recirc has she ?
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    On the ka's the cold setting only reduce the air temperature by a low amount on models with no air con, so if the air temp is higher, the cold blower stays warm
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    I've had this issue and replaced the heater control valve twice - cos some ford forum post told me too!
    http://www.ebay.co.uk/itm/HEATER-CON...item19d1c55c8b
    But she still cooked the occupants!
    I then replaced the actual control panel and that fixed it properly!
    http://www.ebay.co.uk/sch/i.html?LH_...Model=Ka&rt=nc
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Its probably the heater control valve - located in the front scuttle tray - if you follow the heater hoses that leave the engine block where the go into the bulkhead you will find the valve - the two pipes go into the valve and come out the other side into two more hoses that go into the heater matrix in the cabin - the hoses are all held on with hose clips just disconnect them disconnect the electrical connection and pull it out - easy enough to do - its the same on older Fiestas and the valve fits both models. They usually fail open or closed leaving you with hot air or cold air only This is one but check your ma's year and model http://www.ebay.co.uk/itm/Ford-Fiest...ht_2457wt_1271
    Jun 2009
    South Coast
    I have been looking more to the heater control valve as it appears to be a common point of failure on these, I also did read elsewhere that the panel can also be faulty on 1 in 20 cars and needs to be replaced..
    I reckon I may start with the valve as you did as its cheaper and then try the control if it persists..
    Jan 2012
    Essex
    Yep that was my method too - BUT if you do happen to buy a contol panel dont worry about the facia colour, just get the correct buttons etc, the actual coloured facia can be swapped for the original one!
    Jun 2009
    South Coast
    thanks.. handy tip, i thought that may be the case..
    Jan 2012
    Essex
    Quote Originally Posted by Caveman_nige View Post
    Lol, I didn't know and they wife drove round with a silver one (rest is graphite) for months..........
    Jun 2009
    South Coast
    finally fitted this part today and it fixed it.. what pita to it though..
  1. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  2. very little air coming out of vents
    By reeseandellie in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 16:54
  3. smoke/dust coming from air vents
    By adfrodsham in forum Bodywork & Interior
    Last Post: 16th May 2009, 14:41
  4. NAT settings
    By Guyver1 in forum Games Room
    Last Post: 26th March 2009, 11:36
  5. Why ford drivers should stay ford drivers
    By DAVO in forum Comedy & Humour
    Last Post: 10th February 2008, 19:56
hot air coming out of vent in ford ka
ford ka cold air vent
