Thread: CAR PASS general
    May 2012
    Denmark
    Default CAR PASS general
    Hi,
    Just a quick enquiry. Looking into tying in some bits and pieces to my 07 VC - however this CAR PASS that people are on about.
    I have one which came with the car, however looking into changing the head unit + display.
    Might be a silly question - but does the security code change with the HU, or is it car specific?
    thanks.
    -Mads
    Jan 2012
    Silverstone village
    After-market units will have their own code or a detatchable front
    May 2012
    Denmark
    sorry - should have specified, I'm changing from CD30 MP3 with GID to CD70 + CID, no aftermarket units here :-)
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The code is car specific and for best results you would ideally get the code or a divorced setup however the HU and Display are paired so if they have come from the same car they will work in yours just becomes tricky if you want to add extra functiions where you need to program the display or HU if you don't have the original car code. There are also companies that can read and reset codes for you as well.
    May 2012
    Denmark
    hmmm - just to follow up on this.
    I DO have the car pass and hence my security code - however the CD70+CID which I'm epxecting today - is it so that if I want to add-in Bluetooth (UHP)then I need:
    a) my car's security code, which I have
    or
    b) I need the donor cars security code?
    or
    c) something completely different?
    thanks.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You need the donor car's security code once you have this you will be able to put unit into your car and use donors code to reset stereo and CID then code it using your car pass code.
    Irmscher Insignia CDTI 130
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    You need the donor cars code and your own to add functions... as bigmac said, its best to get a divorced unit, makes things alot easier.
    May 2012
    Denmark
    ok - and if the seller doesn't have this, then the seller should be able to get the VIN ID and then get a security code from Opel/vauxhall?
    If this is the case - and I get the code - then essentially I would have 2 car codes, one for satnav programming and one for the rest of the car?
    Probably not the best place to ask - but how difficult is to reset/find the code for the radio I wonder...
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Normally when buying from scrappy non of this information is available e.g.:Reg, VIN as these are normally removed from cars before being sold.There are companies on eBay and net that can set both CD70, CID back to a divorced state ready for your code.
    May 2012
    Denmark
    ok - I think I might have found a company which can decode the code for the radio based on radio serial number and not VIN - hopefully this works.
  1. car pass help
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2013, 22:51
  2. Will my DTI pass its MOT after a De-cat?
    By Innes in forum Diesel Engine related
    Last Post: 12th April 2011, 19:44
  3. Mot pass
    By phant in forum General Chat
    Last Post: 26th September 2009, 11:21
  4. will it pass the m.o.t?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 18:26
  5. PVS Car Pass available
    By cameraman in forum PVS 2007 - 3rd June
    Last Post: 28th May 2007, 16:15
