Results 1 to 3 of 3
Thread: Rough road sensor, Vectra VXR
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Rough road sensor, Vectra VXR
    Can someone tell me where this is.
    Just been taking a look at a fellow members VXR which had IDS/ABS/TC lights.
    I traced the abs fault down to a broken wire between the HUB and the body loom on the front passenger side and i've fixed the wiring which has extinguished the lights
    The only remaining fault is now down to the rough road sensor which I understand to be a sensor that detects rough roads and disables the missfire detection system. Is the sensor down at the hub too?
    The abs cable was worn through and the wire had corroded and when testing the plugs there was a short between all of the wires which after spraying wd40 into the plug most of the shorts were gone. The abs wire is now obviously in need of replacement as it was pretty badly scuffed so I am assuming said wire is also giving the rough road sensor fault.
    Is the black box next to the hub the rough road sensor?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Bump
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Not sure tbh Mate never had a fault with one can u not try opeloem where all the part numbers are and description you might get it from there where the pictures are exploded
  1. Vectra c 1.8 sri 2006 running very rough and eml on. Plz help
    By sambohev1 in forum Engine & Drivetrain
    Last Post: 6th November 2012, 21:12
  2. 2.2 vectra running a bit rough
    By tweenage in forum Engine & Drivetrain
    Last Post: 20th January 2012, 16:20
  3. Vectra C Sluggish and Sounds rough after MOT
    By cheliboy in forum Engine & Drivetrain
    Last Post: 5th November 2010, 22:38
  4. VECTRA SRI CDTi 150 1.9 ROUGH IDLE
    By nafmughal in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2010, 23:23
  5. Silver Vectra, Beverley Road / Sutton Road, Hull
    By AngryDog in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 4th August 2009, 19:30
rough road sensor vectra
rough road sensor location vectra
vectra.vxr bumpy roads
