Thread: revs low in neutral
    Jul 2012
    Shropshire
    Default revs low in neutral
    Not sure if there is already anything on this, had a quick look bt didnt see anything. Basically, i just did the airbox mod (5min job) but cudnt go for a spin cuz kids in bed, missus at work. Anyway, i started it up afyer putting everythin bk tgether an when i revved in neutral, it wudnt go mote than about 2500rpm, even with pedal on the floor. Only had car two weeks (1.9 cdti 2005 sri) so not sure if this is normal. Never revved in neutral b4 so no idea.
    Jul 2012
    Shropshire
    Sorry for all the typos in that guys :-\
    Merseyside
    Have you checked the connector on the MAF sensor to check its secure??
    Jan 2012
    Silverstone village
    Quote Originally Posted by signum_1.9 View Post
    Jul 2012
    Shropshire
    didnt think of that , although i didnt un-plug anything anyway. simply unscrewed and lifted lid out of way, removed the bottom 'trumpet' thing, plonked in filter and screwed back down. Also removed the short piece of flexi pipe that attaches to filter box. read others have done it so giving it a try. wont know till morning though. I wasnt sure if the engine should rev through the whole range when in neutral, or it was designed to stay at low rpm for what ever reason.
    Merseyside
    It should rev freely in neutral - its possible the connector has worked loose seeing as youve had the lid off the airbox - if there are any faults detected its straight to limp mode, which is the 2.5k rev limit you have found. Its a simple fault to check for, just check its secure and check the MAF is on the right way around..... I had a VX tech try and put mine back on the wrong way around a few years back!!
    Jul 2012
    Shropshire
    Thanks for all the quick replies guys, but it was me been a plank. Just been out in the dark, luckily i park under a street lamp so could see quite well. I had only forgot to re-connect the flexi hose from the air box. No wonder it went into limp mode
    Thanks again for quick responses, will update tomorow if all is ok (should be now)
    Merseyside
    Quote Originally Posted by dan21 View Post
    Simple enough as we said. It should run fine now and rev freely in neutral. Any other issues then post away mate, someone will always help you out.
    Jul 2012
    Shropshire
    well guys, thanks again. as expected, all is fine today. and the turbo whistle is definitely louder, and seems to run smoother in all gears.
  1. 3.2 auto g/box going to neutral
    By JG2530 in forum Engine & Drivetrain
    Last Post: 3rd May 2013, 23:31
  2. Gear stick going into neutral problem
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 8th January 2012, 10:52
  3. Auto neutral - again
    By Robert Greenway in forum Engine & Drivetrain
    Last Post: 15th January 2009, 22:03
  4. gearbox stuck in neutral
    By nobel in forum Engine & Drivetrain
    Last Post: 30th October 2008, 21:48
  5. stalling in neutral
    By woodylove101 in forum Engine & Drivetrain
    Last Post: 30th June 2008, 19:55
