Thread: Fans not blowing?
    Jul 2006
    Question Fans not blowing?
    Got in my car this evening to come to work, noticed that the windscreen was steaming up a little bit, so turned the fan up from 2 to 3. Nothing happened. Turned it up to 4, and a force 9 hurricane whipped through the car. Back to 3, nothing again. Turned it off completely, then slowly back through 1, 2, 3, and no fan at all.
    Outside temp was 5.5, air con was on, and heater control was set about halfway round.
    Never noticed this before.....any ideas?
    [Ex]Admin Duncan's Avatar
    Have a look at this thread.
    Dec 2005
    St Helens
    Happend to us about 2 months go - you need a new switch! - I seems a few of these have gone recently
    lancs
    mine only blows on 4, replaced the switch and it still does the same, any ideas
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Someone fixed this with pics included. Think it was a fuse in the actual fan housing caused by condensation build up. VX cure this by drilling a little hole in bottom of housing after replacing the fuse. Will try and find thread.
    lancs
    thanx mate
    lancs
    only got the car three weeks ago for the wife, and i totally love it to bits and this seems to be the only problem with it.
    Vehicle : SRi
    Mileage : 137000
    "Complaint: Blower motor is running only in high speed, is without function or running when ignition is switched off.
    Cause: Condensation water from blower motor accumulates at bottom of blower motor housing ( rust formation etc. ). Resistor is damaged.
    Production: As of VIN W0L0ZCF3561069032 (13.01.2006) improved parts have been introduced in produktion.
    Remedy:
    In case of customer complaint check resistor and blower motor for water marks or rust. Drill a 4 mm hole at the lowest point of the blower motor housing (brush area) when the blower motor is removed."
    This is all I have found at the moment, will keep looking.
    Vehicle : SRi
    Mileage : 137000
    Here you go, this should help, part numbers, price and pics all in post.
    http://www.vectra-c.com/forum/showthread.php?t=21620
    lancs
    thanx for the help rushy, really helpful,appreciate it mate,will get part tomorrow. cheers again
  1. Air con blowing out warm air
    By Baggers 2.0 in forum Troubleshooting
    Last Post: 11th August 2012, 17:26
  2. heater fans not blowing
    By Jaspa in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 16:37
  3. No hot air blowing from vents
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2011, 22:06
  4. only blowing hot air
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 13:19
  5. cat blowing fault
    By rickyroo in forum Engine & Drivetrain
    Last Post: 11th May 2008, 09:44
