Results 1 to 10 of 22
Thread: How Hard To Fit HID's
    Barrow In Furness, Cumbria
    Default How Hard To Fit HID's
    I know the HID discussion has been done to death, but how hard is it to fit them?
    The ones on eBay all say plug and play, but are they really?
    I've seen a how to on here but it was done a fair few years ago when the kits were around £250.
    Also would I need any adapters or cancellers etc?
    Jul 2011
    UK
    Year : 06
    Take 10 mins for me to do it now remove/drop bumper remove headlights and just plug them in really is simple ul need cancellers
    Regular Member sinless's Avatar
    Nov 2011
    Edgware
    Vehicle : Insignia
    Trim : Exclusive
    Engine : Y20DTH
    Mileage : 96500
    It depends on what you want to buy. my advice is go for something that everybody recommends ,something from hid direct (this is what i got)
    It took something like 30 mins to Ian to do it (once again Ian you`re the man) and it looks AMAZING!!!!
    11 Post(s)
    I bought my canbus pro kit from www.hids4us.com approx 3 years ago for my facelift Vectra.
    To fit was pretty much plug and play. Bumper off, headlights removed, and I mounted the ballasts in the dedicated spot under the headlights (where factory fit ones go) http://www.vectra-c.com/forum/showth...=1#post1060742
    Took me just over an hour in total to fit.
    Only problem that occured was that one of the multiplugs wouldn't go through the 22 mm hole I cut in the headlight rear cover for the rubber gromet. I simply removed the plug by inserting some watchmakers screwdrivers to release the locking clips, pushed the wires through ,and reconnected the plug.
    No bulb warning errors, no additional cancellors to fit. All the necessary electronics for that are built into the ballasts.
    The link doesn't work.
    Do you really have to remove the bumper? Can you not just remove washer bottle neck and air box.
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    i didnt take my bumper tbh
    So, the wiring for them.... You unplug the connector for the headlight... Plug it into one end of the HID cabling and then connect the other end to the HID bulb?
    Full Member gibbon7000's Avatar
    lincs
    They are not quite plug and play, you do need to cut a hole in your existing bulb cover/cap for the hid's to fit thru. Taking the front bumper off is a 5 minute job
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    sort off but you need the cancellers in there as well
    Thanks for the replies. Is the hole just for the wiring to pass through?
  1. 50w or 35w HID's?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2012, 08:21
  2. hid's wtf
    By robshortman in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2010, 13:42
  3. HID's Once Again
    By JohnWilson in forum Styling
    Last Post: 1st September 2010, 21:46
  4. More on HID's
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2009, 17:58
  5. hid's
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 19:16
