Results 1 to 10 of 14
Thread: Windscreen Replacemet, Would This Work?
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Default Windscreen Replacemet, Would This Work?
    Hi,
    As you may or may not know, I work for RAC Autowindscreens, so its obviouslty just my luck going to see family on boxing day, I had a stone flicked up from the car in front and cracked my screen.
    What I would like to know is, can I fit a heat reflective, I know I physically can, but what I am not sure about is if it will affect my Air Con?
    I know when we replace screens we can only fit like for like, especially on Renaults as on the newer ones, all Renaults with AirCon have a heat reflective screen, and if we were to fit a different one, the air con or climate control won't function properly.
    I can get the screen, and fit it, I just want to know if it would cause problems with my A/C, and if so, is there a way around it?
    Regards,
    Chris Schild
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The vecs with climate control have a little sensor in the little grill on the dash. This sensor adjusts the temp in the car according to if the car is in shade or direct sunlight (I might be wrong on this but am sure its what its for). So as yours has probably only got A/C like mine, and does not have this feature, I cant see and difficulties in fitting a heat reflective screen.
    Feb 2006
    Dorset
    Wont make any difference infact it helps the aircon , the screen reflects a bit of heat , next time mine goes im going to get one i think , on screen no.4 since end of may so shouldnt be to long ...
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Thats what I thought, climate control sets the temperature, air con only conditions the air through the fans in the same way as normal air vents, except its conditioned!
    cheers,
    i'll think i'll order the screen up tomorrow~!
    [Ex]Admin Duncan's Avatar
    Yep, that's exactly what it's for. If it detects that sun is shining on one side of the car, it will compensate with the CC on that side.
    So as yours has probably only got A/C like mine, I cant see and difficulties in fitting a heat reflective screen.
    I would think so too. If it had the CC and the sensor, it might need some sort of recalibrating as the sensor would be picking up less sunlight falling on it and wouldn't then compensate, yet you'd still be getting the sun hitting you through your side window and making you hotter. Not an issue with AC.
    Feb 2006
    Dorset
    The ammount of light through the screen is the same but it blocks uv and heat , the sensor measures light so wont be affected .
    Without going off topic too much, the sensor measures infra-red - that's why the dome is coloured that red colour. Compare it to the little window on a remote control. If it simply measured light it would have a clear or translucent cover over the sensor. The heat you feel from the sun is infra-red, and a heat reflecting screen will reflect some of this heat, i.e. infra-red, so less infra-red would fall on the sensor.
    Regular Member cameraman's Avatar
    Leicester
    Always wondered what that little dome thing was!
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    The other thing to watch out for is if you have a Tom Tom/Speed camera detector or other device that picks up GPS and sits under your windscreen (without an attached external antenna) it may stop working with a heat reflective windshield fitted since they also do a good job at blocking GPS signals too.
    Dave
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by ukanalyst View Post
    Dave
    Old man had this problem but instead of getting an external antenna he got one that went on his parcel shelf.
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. Windscreen
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2010, 08:11
  3. windscreen wipers don't work
    By clive3373 in forum General Chat
    Last Post: 7th December 2009, 22:54
  4. To work or not to work that is the question
    By garvey in forum The 'Off Topic' room
    Last Post: 31st December 2008, 19:02
  5. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
