Thread: Z30DT stops
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Default Z30DT stops
    Hi!
    Today I found new problem- standing at red light engine stopped! After turning on no check lights etc!
    Becfore I checked DPF fillment with TECH, maybe some CAN error started or somebody met this problem too?
    Regular Member sir pingu's Avatar
    Jan 2012
    Klarup DK 40 cm away from Keyboard
    Vehicle : Vectra Estate Irmscher 3.0 CDTI
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    Mine did that to, it stooped, when I started to use diesel addetive. I think it had something to do with starvation from injectors - correct me if I'am wrong.
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Posiably! Before I used moto oil, this was tanking without additive! try to make fuel feeding and check again!
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Eavning I checked with TECH- was rouble code for rail pressure! Possiable tat some injectur is stucked?
    Jan 2012
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    Quote Originally Posted by Johnny-B View Post
    Perhaps. Was the trouble code P0093-00 ? Then its possible one or more of the injectors is bad, but again try with diesel addetive for a while.
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Talked with ours senior diagnostics specialist- seems that problem will be is SCV try to change fuel filter and drive for some time! If some kows DENSO number for this kit please share, as in deasel- center they cannot found by GM number!
  1. blow starts then stops ??
    By bert01909 in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2011, 12:33
  2. car just stops???
    By kiwiboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 09:18
  3. Bump Stops - Help
    By Ian S100 in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2010, 20:15
  4. 1.8 low power, stops when hot
    By gassy in forum Engine & Drivetrain
    Last Post: 27th May 2007, 19:06
  5. bump stops.....
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 00:19
