Thread: 2.2 direct spanner light help!!!!!!!
    sheringham
    Default 2.2 direct spanner light help!!!!!!!
    hi i have an 05 2.2 direct vectra the car is running fine until it sits in traffic as soon as the temperature guage goes over 90 the car/spanner light comes on the engine keeps running and then just dies.the car will then just turn over and over and will not start for quite a while or the car has cooled down,this just gets worse and worse while driving in slow or queeing traffic any help much appreciated.i have had the fault codes read and it was showing p 0304 cylinder 4 misfire the garage reccomended replacing plugs done this but still exactly the same as i thought .
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    have you had the coil pack checked??
    Full Member spennny's Avatar
    Blantyre
    That's what happened to mine , over 90 and went into limp mode , AA Pointed to the fuel reg , was actually the pump , as soon as it cooled it ran but when it heated up , boom , limp mode
    Sent from my iPhone 4s using Forum Runner
    sheringham
    hi thanks for the replies it doesnt go into the limp mode it puts the other light on its a car with a spanner in the middle,fuel pump and fuel pump regulator replaced when i first got it.
    i havnt had the coil pack checked is there an easy way to do this?
    Dec 2011
    Seaham
    Borrow someones that you know is good!
    11 Post(s)
    Quote Originally Posted by pj2511 View Post
    That is the light that tells you the car has gone into limp home mode. It's the engine electronics, autobox (if fitted) and immobiliser fault light - if flashes and car won't start.
    The engine block light (used to have a lightening bolt through the middle of it) that usedto be the limp home light on older Vauxhalls is now the emmisions fault light.
  1. Vectra 2.2 Direct Auto Car and Spanner light
    By m2yuout in forum Engine & Drivetrain
    Last Post: 11th February 2013, 20:43
  2. 2.2 Direct spanner light. Help!!
    By jrh1 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 22:14
  3. 2.2 direct spanner light
    By DaveB in forum Engine & Drivetrain
    Last Post: 12th April 2010, 20:28
  4. 2.2 Direct,flat spot then spanner light
    By johnmac in forum Engine & Drivetrain
    Last Post: 12th July 2009, 14:08
  5. 2.2 Direct Spanner light then dies....help please
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 14th October 2008, 09:41
