Thread: 2.0 DTI Turbo Whoooosh!
    Northants
    Question 2.0 DTI Turbo Whoooosh!
    Have a 2.0 DTI which has developed a strange problem. Basically I'm getting a really loud 'whooshing noise' (technical term) which I'm assuming is from the turbo. Initially I thought it was the heater fan gone mad, but realised it must be the turbo, it sounds like the turbo has been moved to somewhere behind the dashboard. Added to this the performance is even flatter than normal and if I accelerate hard it immediately goes into limp home mode at around 3500 rpm. I can't replicate this problem when the car's stationary on the drive. Any ideas please.
    Jan 2012
    Silverstone village
    Have you checked the inter-cooler pipes, sounds like you have an air leak between the turbo and inlet manifold, the "whooshing" will be air escaping under pressure.
    Check the pipes ,sure if you Google a bit you will be able to find the common culprits , normally a single section is the weak point for a particular car.
    This would give symptoms of lack of turbo as the pressure will be lower.
    ps. don't do as I did and lye under the car while your brother blips the throttle and up with a face blacker than a black board.
    West
    as above... split boost pipes are common on the dti
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As others have said, sounds like a blown boost pipe. Get the car hot and someone to rev it. Rev hard enough you'll see the boost pipes expand showing the rip. Just don't run your hands over them!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    if the hoses are ok then you will have a cracked intercooler
    Jul 2009
    Engine : 20 Dti
    Regular Member scania666's Avatar
    May 2011
    Wakefield
    have you found the offending hose yet as mine is the same lol
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. My new 2.0 Turbo Sri
    By paulzafgsi in forum Quick Photo Album
    Last Post: 9th June 2009, 21:59
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
