Results 1 to 10 of 15
Thread: Very poor performance 1.9 cdti
    Aug 2012
    burton uk
    Default Very poor performance 1.9 cdti
    Hi,
    Ive been reading this thread (http://www.vectra-c.com/forum/showth...t-pipes/page20) as my brothers 1.9 cdti is really performing badly and the engine management light keeps coming on. Checked it for him and the error codes pointed to an air leak. checked all the pipes, bent them etc all look good but ill replace for him eventually. So I kept reading and took the advise and checked the EGR, whilst caked with soot the movement was very good so just cleaned it off a bit and refitted. Moved to the boost solenoid and this was very very dirty. Cleaned it with carb cleaner the best i could, popped it back in went for a quick spin and the car wasnt smoking anymore and ran lots better. Well better than it was!
    Fired it up this morning and we are now im getting a P1109, the dreaded swirl activator.
    now the car goes into limp mode as soon as you touch the throttle. Is this really the Swirl? Has this had a knock on effect, fix one thing then along comes another?
    Any help would be appreciated.
    Simon
    Jan 2012
    Silverstone village
    Have you looked at the swirl flaps? , maybe the carb cleaner cleaned some of the inlet manifold and it ended up gunging it up near the swirl flaps?
    If the EGR was that caked up with soot then the inlet manifold will be the same , although unfortunately the EGR is allot more robust than the swirl flaps..
    The only way you will know is to look into it.
    Jan 2012
    Silverstone village
    Double post
    Aug 2012
    burton uk
    Thanks,
    Ill take it off tonight, is there an easy way to look or test the swirl flaps?
    Simon
    Jan 2012
    Silverstone village
    Not sure its an easy job reading more on the subject,
    Have a look at the How2
    http://www.vectra-c.com/forum/showth...45#post1338145
    Merseyside
    I had the P1109 code - it was intermittent and rendered the car useless when it kicked in - a new actuator later and a manifold clean I'm assured its as good as new - time will tell but its a pain in the backside if I'm honest, its the most troublesome part I've ever come accross!
    Aug 2012
    burton uk
    Thanks for the replies.
    Ive just given it a damn good clean - Well the best I can inside the manifold area. Took it out and I am no longer getting that dredded code. I am however still making my rear view mirror look worse than a working mens club before the banned smoking!
    I have cleaned the boost pressure sensor again as it was chocked a bit again and it seems to perform better even with all the smoke. Under load though I get a P2279, Intake Air system leak. I have checked the boost solenoid pipes as said before and all look sound. The big pipe from the intercooler also looks good, any more I should check?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Have someone rev the engine past 3,000rpm (2,500rpm should be ok) and you watch the 3rd swirl pot (regardless of the state of the swirl bar) - it should move from the 10 o'clock position to the 2 o'clock position. if it doesn't the actuator has packed in. Another common problem regarding air leaking is the intercooler.
    Merseyside
    Quote Originally Posted by GazCDTI150 View Post
    The smoke you see pouring out the back is cack that has loosened itself from insid the manifold. It should die down after a few good drives. Mine was smoking like a trooper before after the manifold clean and Swirl Actuator replacement.
    Aug 2012
    burton uk
    I also thought it would be the cack but it still hasnt calmed down. Could the boost pressure switch be playing up?
    Simon
  1. poor performance
    By dirtball-tony in forum Engine & Drivetrain
    Last Post: 5th October 2011, 09:16
  2. CDTI 150 Warning Light + Poor Performance at low revs. Please Help
    By tilleyedie in forum Engine & Drivetrain
    Last Post: 10th February 2011, 13:50
  3. 3.0V6cdti Poor Performance
    By Les Scott in forum Engine & Drivetrain
    Last Post: 30th November 2008, 15:56
  4. very bad shuddering poor performance.
    By jaff in forum Engine & Drivetrain
    Last Post: 13th August 2008, 20:06
  5. Vectra 1.8 poor performance
    By scotstrucker in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 17:41
