Results 1 to 3 of 3
Thread: CDTI Air Conditioning fault
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default CDTI Air Conditioning fault
    I'm sure there was a similar thread to this recently but I can't find it now.
    When I first bought my car there was a delay in power before the car would take off at about 2000rpm. The problem was notably worse with the A/C switched on.
    A few weeks after buying the car a new inlet manifold was fitted but no difference. I cleaned the EGR valve and boost sensor but still there was no difference.
    In June I had the car remapped and the EGR deleted which has cured the flat spot with the A/C switched off but it seems to be getting worse with the a/c switched on.
    When pulling away the car feels very easy to stall (and I have done a few times) and when you put the boot down at 1500rpm the car doesn't noticably pick up speed but as soon as it reaches 2000rpm it takes off like a rocket.
    Fuel economy is terrible with the A/C switched on too....my theory is that the a/c compressor may be starting to seize up but I can't find any relevant threads to suggest anyone else has had the same problem (apart from the one I mentioned at the start of this thread but I can't find it now )
    Has anyone else come across this problem on a Vec or any other VX?
    Jan 2012
    Silverstone village
    I would be surprised if the A/c pump was seizing , i would normally put it down to a faulty egr but you have eliminated that, possibly clean or replace the maf?
    Their is a how2 guide on this.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's not the EGR as it was disabled during the remap. I'll give the MAF a clean but it would explain why the problem is only there with that A/C switched on
  1. CIM Fault 1.9 CDTi 16v
    By jaybennett in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2012, 18:06
  2. No1 Injector fault on 150 CDTI
    By bingo999 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 20:22
  3. 2005 1.9 cdti 150 identify fault?
    By bensterzback in forum Troubleshooting
    Last Post: 16th April 2011, 00:45
  4. Fault Codes V6 CDTI
    By r.bailey63 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 00:11
  5. Fault codes on 1.9 120 cdti
    By Keith Jones in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2009, 19:52
