Results 1 to 7 of 7
Thread: help..or it gets the petrol/match treatment!!
Hybrid View
    Regular Member mikey c's Avatar
    Mar 2009
    Plymouth
    Default help..or it gets the petrol/match treatment!!
    ok not planning on burning it yet but hopefully got some attention!
    Im getting error code p0325 knock sensor circuit.
    54 reg Z20NET with 74k on clock.
    No engine mods except cone induction which has been on 18 months with no issue.
    ECU has been replaced.
    Ignition module replaced.
    4 coil packs replaced.
    wiring has been load tested.
    any ideas???
    It gets eml on after about 2 miles from cold, resets on key. Loses power.
    I have had it looked at by my mechanic who has tech2 and is 18yrs ex vauxhall mechanic.
    Now its bugging us both! are we missing something dumb here? Is the knock sensor in the ignition module that bolts to side of block? or is it totally seperate as a friend of mine thinks?
    Getting fed up losing power at the wrong time and chucking money at it.
    Jan 2011
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Mar 2009
    Plymouth
    Thanks STE. Already seen those. Any other ideas? Can anyone confirm if it is a seperate knock sensor or if built into the ignition module on side of engine?
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    O2 Sensor? MAF Sensor? What exactly is the 'knock sensor'? I assume it means 'petrol' knocking.
    Jan 2011
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    Quote Originally Posted by mikey c View Post
    it seems as if its down to the fuel worth a try
    Regular Member unikarl's Avatar
    Nov 2011
    Grimsby
    Let me know if you go down the petrol/match route and I'll ppark mind next to it... 2 birds 1 stone ( or match!)
    Mar 2009
    Plymouth
    Quote Originally Posted by unikarl View Post
    makes sense to go halfs on the fuel....95 ron should be fine
  1. Oil Treatment & Change
    By wotsthestory in forum Engine & Drivetrain
    Last Post: 4th January 2010, 11:59
  2. anyone got some petrol and a match?!?!?
    By TKD Colin in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 19:27
  3. Fuel Treatment.....
    By Signum_CDTI in forum Diesel Engine related
    Last Post: 30th December 2007, 02:03
  4. Laser Eye Treatment
    By T4M in forum General Chat
    Last Post: 20th December 2007, 16:45
  5. Redex or similar..petrol treatment
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2006, 19:50
