Results 1 to 10 of 14
Thread: LED Angel Eyes
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default LED Angel Eyes
    Hi all, i want to upgrade my angel eye sidelights to led sidelights. what size bulbs do i need and how do i dismantle the light to do this mod?
    Thanks in advance
    EDIT: Also, do anybody know what rear bulbs i can fit leds to without the light warning?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Here's what you need:
    http://www.ebay.co.uk/itm/10x-T5-286...item3f1a507feb
    Although some members use the 'triple smd' ones to decrease the hotspot effect.
    To replace them, remove plastic covers on the back as you would when changing a bulb. The halo bulb holders can be removed from their seats by a gentle tug. No need to split the headlight unit up. Access isn't the best but it is possible to change all bulbs in a headlight unit.
    Jul 2006
    Northampton
    Trim : Sri
    Thanks Gaz, will these not throw up the error light?
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Long nose pliers and reptile tongs are accepted forms of extraction and replacement.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Danwells72 View Post
    Yes, your screen will display the passenger sidelight being out.
    Jul 2006
    Northampton
    Trim : Sri
    mmm... got a link to the triple smd ones and how do i stop the bulb out warnings?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Don't know what the triple ones are actually called m8 but I know Ian Highlander has added a resistor to each of his headlights to stop the strobing.
    Jul 2006
    Northampton
    Trim : Sri
    mmm... interesting. a little more research and i think ill be starting this. im going to tint the headlights but want the light to be clearly seen. Cheers
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    286 t5 3smd leds are the lights u need the resistors are the 10w ones fron hids direct( the gold ones) if you cant find the drop ian highlander a pm as he sent me the link ,the above will not give errors if fitted together but they will strobe.
    hth
    Jul 2006
    Northampton
    Trim : Sri
    thats good thanks. im not bothered about the strobing but the error lights are annoying!
  1. Angel eyes
    By blackbeauty in forum Styling
    Last Post: 11th October 2011, 19:54
  2. New Angel Eyes
    By JohnSH8892 in forum Styling
    Last Post: 30th September 2011, 07:53
  3. Angel Eyes...
    By Dwabo in forum Styling
    Last Post: 29th January 2008, 00:57
