Results 1 to 10 of 14
Thread: Engine rattle
    Aug 2010
    Huddersfield
    Default Engine rattle
    I have the 1.9 150 & it has just started to rattle. Easiest way to hear the rattle is when the car is stood still and the accelerator is pressed then released. It rattles mainly when the revs drop back down to idle, it doesn’t matter whether the clutch is pressed or not
    Any help would be great
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    mileage please ?
    have you had the cambelt and waterpump done recently
    Aug 2010
    Huddersfield
    Milage is 90,000. it had a new cambelt and water pump at 75,000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by chillin_man View Post
    was it the full cambelt kit from vauxhall ? ie tensioners
    who fitted it?
    Aug 2010
    Huddersfield
    A local garage fitted it that has done a fair amount of work on it. I have no idea about the cambelt kit as my knowledge of engines is limited
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    has the car had a new clutch ie dmf
    Aug 2010
    Huddersfield
    No it hasn't, i've had a lot of problems with the inlet manifold which has jsut been resolved by giving the car a propper decoke
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Don't know if "Diesel Knock" has ever been an issue with the 16v engines????
    Mine is a little similar (mines an 8v though) but is starting to rattle more and more and sound like a Massey Ferguson. Its had an oil change about 1000 miles ago (using GM Dexos oil) and had the MOT done last week.
    Got chatting with the mechanic and I suggested it sounded like valve shims/tappets (on the 8v only, 16v has hydraulic lifter I believe). Mechanic said it sounded more like Diesel Knock causing the engine to shake/rattle more
    So for me it sounds like it could be injector related or pump related.
    Good luck getting to the bottom of it
    Damo
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    have a look at this thread maybe related
    http://www.vectra-c.com/forum/showth...77+swirl+flaps
    but i would get the water pump checked ie original one from vauxhall
    clutch checked
    engine mounts checked
    as well as the above
    im sure the lads on here will be along shortley with there views
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Small ends ?
    Have a listen to this and is it similar, (I know its a different engine but the symptom might be the same).
    http://www.dhrc.rchomepage.com/omega...end-rattle.wmv
  1. VVT Engine Rattle.
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 27th November 2013, 18:24
  2. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. engine rattle
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 1st December 2009, 22:23
  5. Rattle on engine
    By andymcniven in forum Engine & Drivetrain
    Last Post: 7th January 2007, 11:49
vectra 1.9 rattle with kn filter
