Results 1 to 10 of 18
Thread: Vectra C Turbo overheating
    Jan 2012
    Darlington
    Default Vectra C Turbo overheating
    Hi
    My Vectra turbo is overheating, normally the temp gauge shows about 1/4 when i slow down it goes about 1/2 way then fan kicks in. Does anyone have any ideas what this could be.
    Andy
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Petrol or diesel?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Jan 2012
    Darlington
    Sorry forgot to say its petrol
    Jan 2012
    Silverstone village
    Faulty thermostat, or low on coolant?
    Jun 2009
    South Coast
    6 Post(s)
    You have to start with what said above
    Jan 2012
    Darlington
    Hi
    How do you check if its the thermostat thats bust
    i ran engine till fan cut in i coudn't see any flow threw header tank then removed cap and there was no preasure there don't know if its susposed to be like that
    cheers
    Andy
    Jan 2012
    Silverstone village
    If the thermostat is faulty the radiator will not get warm if failed closed, otherwise if it has failed open then the car will take an age to warm up if it does, should sit at 87 degrees when warmed up , regardless of driving conditions, if your gauge drops when going down the motorway your thermostat is shot.
    Jan 2012
    Darlington
    Quote Originally Posted by mon View Post
    Hi
    Sounds like mine is stuck closed then as the faster i go the cooler the engine gets and i did feel the radiator and that was cold
    Ordered new one £8.95 plus vat pick it up later just need to find where it goes now
    Many Thanks
    Andy
    Quote Originally Posted by SriTurbo1 View Post
    That sounds quite normal to me
    It is showing a normal temperature during driving, then rising when you stop
    I would be more worried if the radiator fan is continually having to switch on, say more than twice, as the engine coolant system reheats
    Is this the case?
    Jan 2012
    Darlington
    Hi
    Changed thermostat still no change
    Fan comes on anytime it over heats soon as i slow down temp goes up, get a bit of speed up it comes down again
    Anymore ideas
    Andy
  1. Vectra 1.9CDTI Overheating
    By brad69bj in forum Engine & Drivetrain
    Last Post: 19th June 2012, 15:47
  2. Vectra overheating to 100
    By manugasau in forum Engine & Drivetrain
    Last Post: 11th April 2011, 18:15
  3. Vectra losing power & overheating
    By sr310583 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd April 2010, 10:58
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
vectra 2.0 turbo overheating
car started running hot and losing water z20net
my vectra c is running hot
signum turbo overheating
how much coolent dose a vectra c turbo use
vectra c running hot
vectra c z20net engine gauge temperature www.vectra-c.com
vauxhall signum 2.0 turbo overheating
vauxhall signum overheating 2.0
