Thread: "Handbrake" Light coming on (54 Plate facelift)
    Cambridge
    Engine : 3.0 V6 CDTI
    Default "Handbrake" Light coming on (54 Plate facelift)
    Another little query, the h/b light appears to come on, seems to be same place on my journey to work everyday, brake fluid level is fine, and once the engine is off/on again it clears.
    Any ideas?
    Thanks.
    Barrow In Furness, Cumbria
    Brake pads ok?
    11 Post(s)
    Quote Originally Posted by Chris SRi View Post
    Brake pads ok?
    Different light for low pad warning.
    Circle with dashes around its circumferance (3 either side, IIRC)
    West
    If fluid level is fine then it's likely to be switch / sensor fault
    Cambridge
    Where are the sensors and are they easy to access?
  1. GUNGE COMING FROM THE EXHAUST. "Emissions?".
    By felixx in forum Diesel Engine related
    Last Post: 16th February 2011, 06:42
  2. Rear "Check Light" coming on internitantly
    By benmorling in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2010, 18:09
  3. handbrake " CLUNK" how many clicks before ur brake holds?
    By Craig1985 in forum Suspension, Wheels & Brakes
    Last Post: 7th January 2008, 20:57
