Results 1 to 2 of 2
Thread: Removing front and rear door cards for speaker upgrades help
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Removing front and rear door cards for speaker upgrades help
    Hi,
    I'm having some trouble trying to remove the door cards. With the rear i got as far the window handle bit and stuck on how to take that off. And with the front i got most of it off and stuck at the bit right at the top (the section in line with the door pin), i tried pulling, and lift up and pulling but don't want to go any further without breaking it.
    Thanks.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    there is a spring clip that slides off the shaft on the rear window crank,slide a screwdriver or similaralong the back of the crank,put the window fully down first.there are then 4 bolts to unscrew and 4 fastening plugs.the panel then needs knocking up of the door complete with rubber window seal.
    front is same but there are a few more fastening plugs to ease out before knocking the panel up.put window fully down before you start.fiddley but not hard don't force anything make sure you pop all the plugs so that the panel is loose from the door before knocking panel up i use a 10 inch file and knock it with the palm of my hand.
  1. Help. Trouble with removing front and rear door cards.
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 14:54
  2. Removing Rear Door Cards?
    By parapaul in forum Bodywork & Interior
    Last Post: 16th November 2007, 18:05
  3. Removing door cards...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2007, 00:14
vectra c remove door speaker cover
how to remove opel vectra door speaker
Vectra c remove rear door speaker cover
