Results 1 to 2 of 2
Thread: Z30DT - How do I bleed air from the cooling system
    Regular Member ph67's Avatar
    Northamptonshire
    Default Z30DT - How do I bleed air from the cooling system
    Hi,
    Does anyone out there know to bleed the air out of the cooling system on the Z30DT? Previous cars I had used to have a screw or threaded nut on the highest point of the cooling system, gently undoing it when cold used to allow air out of the system (with the header bottle lid unscrewed). Is there such a thing on the Z30DT or is it done in a different way? If you've any piccies it would help very much.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Leave lid of reservoir bottle.
    Turn heater to full an fans off.
    Start car allow to run whilst it's running squeeze bottom hose. Kept doing this an after a few mins all the air should be out
  1. Cooling system help
    By Tinks in forum South Central (ARO - matty2fatty)
    Last Post: 11th December 2012, 21:37
  2. cooling bleed screw
    By Alerxt in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2012, 15:34
  3. cooling system problems
    By vmb2722 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th July 2012, 19:59
  4. Cooling system
    By Tinks in forum Engine & Drivetrain
    Last Post: 21st April 2012, 10:43
  5. some probs cooling system
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 18:00
vauxhall insignia coolant system bleeding
