Page 1 of 8 123 ... LastLast
Results 1 to 10 of 76
Thread: 1.9CDTI stuggle to start
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default 1.9CDTI stuggle to start
    Hi all as title says my 1.9CDTI struggles to start from cold but once started it is fine starts first turn of key i was wondering if it was the heat plugs i changed the fuel filter yesterday as i thought it might be that but nope its still doing it what yous think.
    Sep 2011
    southport merseyside
    Vehicle : vectra club h/b
    Trim : club h/b
    Engine : 1.9 cdti
    Mileage : 150000
    Hi yep mine is the same got a 2005 1.9cdti with 120 8v z19dt engine: i have had the boost off and cleaned also EGR IN BITS AND CLEANED ??? I am losing gases through my front flexi exhaust pipe A guy tells me it will be hard to start until it is replaced?? so just going to put a bandage on it see if he is right before I spend a small fortune on an exhaust system:
    the next thing is to look at the injectors, not well up on them or how to check to see if they are working ok any help please maurice
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Try your starter motor mate.. mine was the same... it was the starter... replaced that and its been fine!
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What's battery is fitted?
    Nov 2009
    newcastle
    had same problem which was the leak off pipes had an air leak causing diesel to seep away from injectors and thus poor start.
    if you take off cover and listen to injector i could hear air seeping when engine turned off
    i changed whole rack set inc clips (£35 +vat part no 9316078 (guy at parts had trouble identifying it as pictue on vauxhall parts looks slightly diff to real one and clips changed to metal) as plastic and snap when you go to do and was the plastic parts that had snapped and will prob snap when you pull them out.
    hope it helps
    had thought was egr or the starter but all solved by this and much smoother running after few starts and miles. (someone has already done a thread on this already for how to and took 20mins inc dropping a pin clip down engine.
    Richie
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Its a vauxhall battery Critch well that's all that's on it lol
    Thanks Richie i will give them a go as i have the old ones anyway as there all yellow clips so they need change anyway.
    scottish region
    Glow plugs ???
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I thought it was the plugs cos once its started and heated up its fine starts first turn every time but left over night its struggles... even if i start it in the morning drive for say 5 mines park it up leave all day and start it it fires up right away.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Hi al again still getting this problem ive checked the injectors they seem fine checked the battery thats fine now its the glow plugs got them so going to do them tonight but what ive just spotted today is the light on the dosh was going out within seconds on the first start but now every time i start it the light doesn't come on at all so is that the plugs or the glow plug relay is there anyway of checking this before i change the plugs. ??
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Well its not the glow plugs the light goes out within 1 second as if there not heating up fast enough to get it going would that be the relay?
  1. where to start with a 1.9cdti 150?
    By bigdave1701 in forum Diesel Engine related
    Last Post: 27th July 2011, 20:07
  2. 1.9cdti won't start!!
    By Gaz84 in forum Engine & Drivetrain
    Last Post: 4th July 2011, 12:17
  3. wont start 1.9cdti
    By otl1uk in forum Engine & Drivetrain
    Last Post: 19th November 2008, 20:11
  4. 2006 1.9CDTI SRI 150 Won't start!
    By Rmac1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2008, 21:36
  5. 2006 1.9CDTI SRI 150 Won't start!
    Last Post: 3rd August 2008, 18:39
