Results 1 to 3 of 3
Thread: Alternative ignition live for Parrot to work when engine off, but key still in?
    Mar 2012
    Norway
    Default Alternative ignition live for Parrot to work when engine off, but key still in?
    The CD30mp3 doesn't shut down before the key is pulled out of the switch, but the Parrot CK3100 (or something) shuts down as soon as engine is off.
    Is it somewhere to get power/control to get the Parrot to work when the key is still in?
    Happens from time to time that the phonecall isn't done when you have parked, but still wants to finish the call on the Parrot before leaving the car. Now I have to keep the engine running just to do that...
    Regular Member TopRod's Avatar
    Liverpool, UK
    I think that the window up and down switch would be a good one. I've noticed when you take the key out of the ignition the windows still work for about 5 minutes and then they stop working. When you just put the key into the barrel without turning they start to work again. But then in theory the parrot kit would stay on for 5 minutes after leaving the car every time. Unless they switch off when the dead lock is activated?
    scottish region
    The glovebox works for 10 mins after locked but only downside is when you unlock it will start straight up
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. ignition live
    By Nessy in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 19:23
  3. Ignition live in engine bay
    Last Post: 22nd May 2011, 20:29
  4. parrot ignition live problem
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2008, 23:18
  5. ignition live
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2007, 20:03
