Thread: Limp Home
    Nov 2010
    confused Limp Home
    My '04 cdti 120 Club keeps going in to limp home mode after I put my foot down full.
    Sometimes it cuts out altogether and sometimes it will do no more than 30mph.
    Under normal driving conditions it it fine but when you give it, say, more than 3/4 throttle it limps.
    Any suggestions?
    Aug 2007
    oldbury
    When we had this it was the sensor in the air stream from the turbo into the air intake. Although the turbo is at the back of the engine bay, the sensor is near side of the rocker cover and not visible with the engine cover on. Follow the rubber discharge from the turbo all the way around and it connects to a cast tube, inside which is the sensor. Ours needed cleaning, but the problem recurrs annually.
    Aug 2007
    oldbury
    I've since resolved a poor acceleration issue with a replacement to a spilt tube on the hydraulics located top and front right of the engine bay.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Split boost pipes possible solder joint cracked on the inlet manifold easy fixes
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Cracked solder joint in the throttle body I would say as your car is a 2004 model or 3rd injector plug is goosed (there is an update/modified part which are blue. Old plugs are yellow). They are the only faults that would cause your car to shut down. Boost pipes would put the car into limp mode and an EGR valve jammed open would cause sluggish performance.
    Throttle Body Fix How2
    Third Injector Loom fix if you fancy go
  1. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. Limp home mode
    By 57alan0 in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 21:02
  4. dam limp home?
    By garry7000 in forum Engine & Drivetrain
    Last Post: 27th May 2010, 23:08
  5. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
