Thread: Hole in driver foot rest carpet
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Hole in driver foot rest carpet
    Forgot to find out what can i do to fix this issue as it been there since i bought the car, a deep hole from the area where u rest ur feet on while driving. I put old mat under the rubber mat so i dont feel the ditch.
    What is a good way to repair the hole?
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    I have exactly the same in mine bud... I bought my car with 1 previous lady owner and it looks like her high heels have poked a hole in the carpet and unfortunately it sits at the side of my Irmy mats so it's visible..... I'd be interested in a fix for it
    Sent from my iPhone using Forum Runner
    Oct 2009
    Aberdeenshire
    could have a look on ebay at cars being broken and get the carpets out of them, but a lot todo just to fix the hole but can't see it being repairable at all really
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    How about a large ring cut it out and same ring on other carpet and cut it out then repair using sewing from underneath? Just a patching up thoughts??
    If i were to replace carpet, will it just be in 4 sections? Driver, rear driver rear pass and front pass, or does it come in whole??
    Jul 2012
    Doncaster
    It's a oner mate! Need to take seats an centre console out luss all the trim low down round bottom of doors and below dash, maybe after unbolt bottom bracket is seat belts but to be fair it's not a bad job easily done in 2 hours.
    Dan
    Feb 2011
    Selby
    The usual way to fix holes in carpet in offices/houses is to cut out the damaged section (ie go a few cm into 'good' carpet), then cut an identical section from another bit of carpet. Get a piece of thin, stiff but slightly flexible plastic, feed it through the hole and glue to the underside of the carpet (lift carpet by the hole, apply strong glue to the plastic, then push carpet down onto it). Glue the patch onto the plastic to fill the hole. Then roll it to get air out and make it sit flat and leave to dry.
    That leaves the carpet at the same level, and hopefully stable enough that if you cover it with a mat it won't cause any further issues.
  1. New Pedals & Foot Rest
    By ScotsDragon in forum Bodywork & Interior
    Last Post: 17th June 2010, 22:20
  2. left foot rest
    By bertxuk in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2010, 16:20
  3. Foot rest
    By grumpano in forum Insignia car chat
    Last Post: 13th May 2010, 16:43
  4. wife put a hole in the carpet
    By BRUCE120 in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2006, 16:03
