Thread: 12" Alpine Sub Buzzing
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Default 12" Alpine Sub Buzzing
    Just noticed my sub has started to buzz when I turn my lights on. My 2 power cables for the 2 amps are running down the opposite side from my RCA cables so they're well away from each other. When I take the speaker cable out of the sub the buzzing stops, do you think my sub has blown the coils? Oh and my Alpine amp that runs the sub the MRD-M1005 show CUR and flashes too.
    Any ideas what's wrong folks?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Almost definitely the voice coils in the sub gone fella. The amp going into safe mode (flashing CUR) is basically it telling you the sub is trying to draw more current than it can provide. Unplug the sub and get it replaced before you damage the amp too.
    Quick test, unplug the speaker wires from the sub (make sure the ends are shorting together) and switch back on, does the amp still give CUR? If it does then the short maybe in the speaker wire or connections in the amp somewhere to the speakers, if it doesn't then it's the sub voice coils
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Cheers Ian I'll have a look once my eyes start working from sleep mode lol. I had a feeling the coils might have popped. Are they repairable or is it a new sub?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    I'm sure a specialist could repair/replace them but it would probably cost ten times the price of a new one
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by Ian-Highlander View Post
    I've did this test Ian and it shows "CUR" so I guess as you say the short maybe in the speaker wire/connections to the amp then mate??
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Only way to test that is to swap out another amp and try it. It's possible there's a short internally in the amp, but less likely.
    Edit: ARRRRGHHH, I've just noticed a typo in my previous post and it's rather critical...
    Quick test, unplug the speaker wires from the sub (make sure the ends are NOT shorting together) and switch back on, does the amp still give CUR? If it does then the short maybe in the speaker wire or connections in the amp somewhere to the speakers, if it doesn't then it's the sub voice coils
    Must type slower and proof read my replies before hitting submit... Sorry...
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Problem solved Ian, the RCA cable for the amp was too close to the POWER cable for it, I hadn't noticed this until I lifted the back seat up again to check these cables. So it's all working again without the HUM. Thanks for the advice mate,appreciated.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Any links to buy upgraded RCA cables for the car?
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Cheers mate.
  1. Lcd buzzing
    By Aikon58 in forum The 'Off Topic' room
    Last Post: 6th December 2011, 19:01
  2. "buzzing/crackling" noise
    By felixx in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 15:52
  3. Alpine V12 Amp and JBL 12" boxed Sub!!
    By jamesy in forum Parts for sale
    Last Post: 12th September 2007, 20:51
  4. Alpine -2 X Type R 10" Subs & 2 X Alpine Mrp-m350 Amplifiers
    By armoured farmer in forum General items for sale
    Last Post: 15th November 2006, 15:11
  5. still buzzing
    By ian_c in forum General Chat
    Last Post: 15th May 2006, 11:48
