Results 1 to 3 of 3
Thread: Worn Thrust Bearing?
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Default Worn Thrust Bearing?
    Noticed the other day, when I actually turned the music down , my car makes a whisttling sound when I have the clutch pressed in and a very slight grating noise as I let it out.
    This happens whether the car is in gear or not.
    I have suffered no drop in drivability nor do I get any clutch slip either.
    Any ideas?
    Sep 2010
    norfolk
    Sounds very much like mine did. When i dropped the gearbox the release bearing part of the CSC fell of the shaft. All noises cured by new CSC (DMF and Clutch). Was initialy suggested by VX that input shaft bearings were goosed, and i should change the GB. Not the case....
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Mine makes funny noises as well, but only can hear it in neutral.
    http://www.vectra-c.com/forum/showth...blem&highlight=
  1. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  2. Thrust Bearing 1.9cdti 120
    By stevie16v in forum Engine & Drivetrain
    Last Post: 11th May 2011, 18:08
  3. Thrust bearing noise
    By robengland9 in forum Engine & Drivetrain
    Last Post: 21st February 2011, 13:48
  4. DMF or Thrust bearing
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 20:52
  5. 3.2 GSI Thrust/Clutch bearing Question.
    By gsi32 in forum Engine & Drivetrain
    Last Post: 4th February 2009, 13:45
3.0 cdti noisy thrust bearing
vauxhall vectra thrust bearing
vectra c thrust bearing
vectra c 1.9 cdti 07 gear box thrist bearing
vectra c clutch release bearing
06 vectra thrust bearing
vectra 3.0 cdti thrust bearing
how to change a thrust bearing on a c vectra
vectra c 1.8 thrust bearing
vectra c zx18e thrust bearing
clutch bearing vauxhall vectra c
vectra c gearbox thrust
