Thread: Spray paint
    Jul 2011
    UK
    Year : 06
    Default Spray paint
    Am going to do my wheels some point but would I be better with star silver rattle or use my mates spray gun but where do I get the paint for it
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    I've just done a set of Corsa Sxi wheels I am tidying up and used rattle cans - grey primer, star silver 2 and clear lacquer all from Halfrauds - really pleased with the results - the only advice I could give is obviously do your preparation well before starting to paint and let each coat dry properly before doing the next - I tried to rush mine when applying the lacquer and it started to crinkle in a couple of places - leave the top coat at least 24hrs before the lacquer is put on.
    Jul 2011
    UK
    Year : 06
    Cheers mate I done my dads yesterday but was rushed and see scratch marks from sanding which I don't want put 4 coats of primer doing each coat 10 mins what sand paper would u recommend this is the results from yesterday
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    I'm no expert and the a couple of the wheels I did were really badly scored - I bought the car of a 72 yr old woman who had obviously just pointed the car at the kerb every time she parked and waited until she had hit it Fortunately the offside ones weren't too bad - the bad ones I had to use a belt sander to remove the gouges and they were never going to be perfect but kept at them with finer grained papers and ended up with a very fine wet and dry paper. Like you, four coats of primer took out any slight scratches and I was pleased with the results - your Dad's looks very good and the lacquer really finishes them off.
    As far as your papers are concerned get an assortment of grades and finish off with a very fine wet and dry paper. Halfords do a filler/ primer which I wish I had used for my first coat as this will cover most minor scratches before putting normal primer and top coats on.
    Quote Originally Posted by marc vectra sri View Post
    A spray gun will give you thicker depth of paint.
    www.Paints4u.com
  1. normal spray paint or caliper paint?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 20:59
  2. Spray paint help
    By Majorlook in forum General Chat
    Last Post: 17th June 2007, 15:44
  3. Spray Paint
    By Damian in forum Styling
    Last Post: 23rd May 2006, 11:50
  4. Spray paint
    By simonali in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2006, 12:20
  5. Spray Paint
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2005, 18:50
