Thread: 12volt socket
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Default 12volt socket
    dose anybody know how2 wire in 12volt socket on the left hand side of the boot.
    Some of you know i like to have a brew (cup of tea) at every meeting so i can plug my cooler box into and keep milk and cold drinks cold, and if any one knows the part number for the socket that will help cheers
    SCOTLAND
    can you not just put the cable through the rear hatch in the armrest into the rear passenger socket bud?
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    did that, but the cable is not long enough to go right back because the fan is on top of the cooler box which is hitting that leather holdall under the back shelf i have fitted
    You can get extension leads for them, seen them somewhere ?
    Also cheers for the drive out of Trax, saved me a lot of time dude ....
    ian get ur self a cig socket from halfords then wire it into the fuse box by the rear lights,ill give you a hand if you want
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Quote Originally Posted by Bainie
    thanks tommy, sat nav not bad i am glad i got it when i got the car
    Regular Member ossypete's Avatar
    Lancashire
    we can fit one in your boot ian, run it direct to the batts so its perm live so you dont need the ign on to run it , just remember to unplug so batt dont go flat !might even be able to locate a perm live in the boot
  1. socket set
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2012, 01:45
  2. USB socket
    By rockonoli1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 13:33
  3. 12volt feed on top of dash? (possibly a question for Kman!)
    By johnny kebab in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 18:45
  4. 12v aux socket
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 20:58
  5. USB Socket/Aux In
    By armstma1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2007, 21:18
