Thread: 1.9 CDTI 150 - Rocker cover gasket change
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Default 1.9 CDTI 150 - Rocker cover gasket change
    Any one changed there rocker cover gasket on a 1.9 150. Mine leaking bad now so needs replacing but told I need to remove the cam belt to get the cover off. Is this correct.
    Liverpool
    Not one person on here changed the rocker before ??????
    Come on folks.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Don't start a new thread to bump this one
    Can anyone help this gentleman out
    Irmscher Insignia CDTI 130
    Liverpool
    Anyone.
    Liverpool
    Is there a single mechanic on here who has changed a manifold gasket on a 1.9 150 ?
    Surely someone has had to make this fix.
    Gav
    Liverpool
    Bump all tho hold out little hope of a response lol...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Hmmm not sure fella have you had. Close look ya self to see what ya think
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If the leak is roughly at the front right of the engine then it's a common fault found on all CDTi 150's and its not worth changing. It usually looks worse than it is. Can you post a pic up?
    Jul 2010
    Londonderry Northern Ireland
    and yes the cambelt has to come off, the camshafts are part of the rocker cover
  1. rocker cover gasket
    By SarahP in forum Engine & Drivetrain
    Last Post: 10th October 2012, 16:12
  2. rocker cover gasket
    By crainer85 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 20:06
  3. 3,2 single or dubble rocker cover gasket
    By speedzone in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 22:13
  4. rocker cover gasket signum 19cdti 150 (56)
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2009, 22:13
  5. Rocker cover gasket
    Last Post: 19th May 2009, 06:48
1.9 cdti rocker cover removal
how long to repair rocker gasket on vectravalve cover 1.9cdtiHow to disassemble the valve cover opel 1.9cdtireplace astra 1.9 cdti rockersvectra 2004 sri turbo removing the rocker covervectra 1.9 cdti rocker cover 1.9 cdti engine rocker cover removalastra 1.9 cdti rocker gasket leakremoving camshaft cover 1.9 vauxhallremove opel 1.9 cdti rocker coverrocker cover removal 1.9 cdtihow to remove insignia cdti rocker coverzafira b cdti 1.9 rocker cover removalgasket vectra c 1.9cdti camshaft coverreplacing valve cover on vectra 1.9cdtivauxhall z19dth cam cover removalinsignia 2.0 cdti rocker cover removalvectra cdti rocker cover removalvauxhall signum.cam cover removalvectra c rocker cover gasketchanging rocker cover gasket on o6 vectra tdcivauxhall vectra cdti cam cover removal rocker cover removal for a vauxhall signum 1.9 cdti 150how long uto change rocker cover gasket vectra c
