Thread: help lights are still on when switched off
    Regular Member scania666's Avatar
    May 2011
    Wakefield
    Default help lights are still on when switched off
    front fogs and rear lights even though switch is off had a play with op com this afternoon now it wont turn off
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Disconnect battery Maye it's the only way if you put them Bak correct
    May 2011
    Wakefield
    im sure i put it all back right a battery disconnect will put it back to normal???
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yep it will mate aslong as all the drls settings you changed are set to nothing diss battery reconnect job done
    May 2011
    Wakefield
    just disconnect it then reconnect or leave overnight??
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Pull it off put it straight Bak on mate
    May 2011
    Wakefield
    that worked cherers staying off opcom now cheers thank you thank you
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    No worries mate lol
  1. We still getting switched off tonight?
    By Mark Evison in forum The 'Off Topic' room
    Last Post: 10th February 2012, 20:55
  2. Fiancée has switched for the better
    By george1987 in forum Non Vectra C/Signum Album
    Last Post: 11th April 2011, 21:37
  3. New switched fitted in
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 22:57
  4. Stereo switched live
    By andyfeeny in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 12:31
  5. Vibration when air con switched on
    By marky2027 in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2007, 22:07
