Thread: Can anyone help with these readings?
    Regular Member Lozza's Avatar
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    Default Can anyone help with these readings?
    I have a slight misfire and sometimes when i start the car it stalls.
    B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
    B1S1 O2 Sensor (Bank 1 Sensor 1),156 mV
    B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Lean <<<< this switches between Rich and Lean
    B1 O2 Sensor Loop (Bank 1),Closed
    B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
    B1S2 O2 Sensor (Bank 1 Sensor 2),801 mV
    B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Rich
    B1 Short Term Fuel Trim (Bank 1),-2 %
    Catalyst Protection Enrichment (Bank 1),Inactive
    Intake Manifold Valve 1,Inactive
    Full Load Enrichment,Inactive
    Desired Engine Idle Speed,688 RPM
    Idle Speed Modified,NO
    Idle Speed Offset,Inactive
    Vehicle Speed,0 km/h
    Mass Air Flow Sensor,0.62 V
    Mass Air Flow Sensor,9 kg/h
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Looks like a list that a faulty maf would cause
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    Big thanks Paulvectrac.... it was the "MAF" after all, car is nice and smooth now would it be best to change both o2 sensors as well?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    no problem glad you got it sorted
  1. New MOT has last 3 milage readings
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 21:33
  2. Need Help with car data readings
    By Mrmac in forum Engine & Drivetrain
    Last Post: 9th April 2012, 23:21
  3. Injector Readings
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 12:23
  4. Is this normal readings?
    By steve1975l in forum General Chat
    Last Post: 26th March 2009, 14:03
  5. Multiple Tech II readings
    By Ncompass in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 12:13
